Intake manifold ?'s
Intake manifold ?'s
Postby 93 W350 LE » Thu May 30, 2013 6:54 pm
What do you guys run? How much of an improvement are aftermarket? Could a guy fab his own? Why does the stock look so restrictve and crappy?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: Intake manifold ?'s
Postby ellis93 » Thu May 30, 2013 6:58 pm
Google coolertubz. A member here builds them,and they work ;)
Postby RCCUMMINS89 » Thu May 30, 2013 7:17 pm
Coolertubz.net , he is a great guy with awesome customer service.
if you are more comfortable with stock take off styles...... the 98-02 24 valve is the best.
Postby 93 W350 LE » Fri May 31, 2013 4:13 am
Will check out the Coolertubes, have seen in alot of sigs and wondered what it was.
Are the 98-02's a direct bolt ob swap?
Thanks.
Eric
93 W350 LE
Postby cmann250 » Fri May 31, 2013 4:30 am
93 W350 LE wrote:Are the 98-02's a direct bolt ob swap?
The side that bolts to the intake heater is, but the side that attaches to the intercooler piping is at a different angle.
Postby Philip » Fri May 31, 2013 6:33 am
CoolTubz's also can supply the pipe to go from the IC to a 24 valve air horn.
Do not use a intake horn off of a common rail engine. It is not the same as a 2nd gen intake horn.
Here is a pic of your intake horn beside a 2nd gen intake horn. Want to guess which one is the 1st gen. :lol:
This is a pic of his IC pipe for the 24 valve air horn.
Here is a pic with the inside view of a 24 valve air horn.
This is a pic of a common rail intake horn. Look at the restriction just inside of the air horn where it changes direction. The common rail horn isn't much better than the 1st gen air horn.
Postby 93 W350 LE » Fri May 31, 2013 7:43 am
Guessing the other is a Coolertubz? Looks like a flange on a mandrel bent tube, nice. I',m guessing not matching the port doesn't cause enough turbulance to have any ill effect on the flow.
Thanks.
Eric
93 W350 LE
Postby Philip » Fri May 31, 2013 1:50 pm
93 W350 LE wrote:Guessing the other is a Coolertubz? Looks like a flange on a mandrel bent tube, nice. I',m guessing not matching the port doesn't cause enough turbulance to have any ill effect on the flow.
Thanks.
Eric
The mismatch doesn't affect anything. I have ran a set of cool tubz's and the 24 valve air horn. Both horns dynoed the same. The only thing I noticed was right at the peak toque rating for our engines. The engine felt more responsive to throttle inputs for some reason with the cool tubz's. Its was real noticable when towing.
Postby 93 W350 LE » Fri May 31, 2013 6:37 pm
Good to know. So the same on paper, but seat of the pants difference. What kind of power gains?
Thanks.
Eric
93 W350 LE
Postby Philip » Fri May 31, 2013 7:18 pm
No power gains shown on dyno. Torque reading showed the same on both runs with each setup.
I dyno'd with the 24 valve air horn. The truck was shut down and left straped on the dyno. Swaped in the cool tubz's and redyno'd.
The noted difference was in the 1500 to 1700 RPM range. With my 3:07's it was a noticable difference between the cool tubz's and the 24 valve air horn. A friend of mine drives my truck every once in a while. About 2 weeks after the dyno runs he borrowed the truck to tow while his truck was down. He noticed the difference also. I hadn't mentioned the difference to him after the swap/ dyno runs.
A week or so later we threw the cool tubz's on his truck. I didn't get them back till he sold the truck last Dec. The dyno runs were 3 years ago. :lol: :lol:
Postby 93 W350 LE » Sat Jun 01, 2013 10:28 am
Sorry. Clarification. What kind of gains over stock intakee?
Thanks.
Eric
93 W350 LE
Postby RCCUMMINS89 » Sat Jun 01, 2013 10:40 am
You're going to notice cooler egts..........and a more responsive throttle.
Dyno gains.........minimal to none.
Postby 93 W350 LE » Sat Jun 01, 2013 12:36 pm
Any improvements in mpg's to be had?
Eric
93 W350 LE
Postby RCCUMMINS89 » Sat Jun 01, 2013 12:40 pm
You might see a mpg............
The biggest thing is you'll notice a better driving truck.
I have 3" tubes and a 24 valve air horn and soon to be 2nd gen intercooler....... now with as much fuel and air as I am and will be running I kind of need it more than a lower hp truck.........however, I originally put them on my truck when it was near stock and it made a better driving truck.
Postby 93 W350 LE » Sat Jun 01, 2013 12:53 pm
Good to know. So it really just helps optimize the mildly tweaked set up, with potential for more.
Eric
93 W350 LE
