Blue smoke ?
Re: Blue smoke ?
Postby welderboy250 » Sun Jun 09, 2013 2:38 am
I vote that a rusty fueling or some such issue is causing it to suck a slight amount of air between the fuel and the lift pump
1990 W350 5spd. IC'd front end, HX52 on ported 3 piece, full 4" pipe, not as much power as I want but more than enough to break something
Jimmy
welderboy250
Re: Blue smoke ?
Postby RCCUMMINS89 » Sun Jun 09, 2013 8:53 am
"generally" air enters the system pre lift pump (suction side).
Double check the inlet of the piston lift pump to make sure it isn't loose by chance or sucking air, same goes with any of the fuel line connectors.
Re: Blue smoke ?
Postby Black93 » Sun Jun 09, 2013 5:43 pm
Does anyone happen to know the part # for the return tee orings?
Black93
