A/C woes
Re: A/C woes
Postby mhuppertz » Wed Jun 26, 2013 6:27 pm
Funny Mark...
Well, I put the multimeter on the hot wire to the compressor clutch and it was dropping voltage when the clutch chattered. So I worked back to the relay on the fenderwell, and it was clicking with the beat of the cutout, so I swapped relays and it did the same thing.
Then I hotwired the clutch and it worked fine.
Since I replaced the cycle switch, maybe the next thing is the low pressure switch?
Mark Nixon wrote:Too hot?
Then this YouTube link from an older 1980's movie is for you:
http://www.youtube.com/watch?v=DpktBGInl60
mhuppertz
Re: A/C woes
Postby mhuppertz » Wed Jun 26, 2013 6:42 pm
Not the low pressure switch.... fusable link would be an on or off kinda deal...
Next check, right headlight ground,... Hmmm :?
Not that either. PCM.
mhuppertz
Re: A/C woes
Postby lopez dodge » Thu Jun 27, 2013 11:15 am
i feel for you . pulled camper back up from abq heading up i25 midday not a/c is no fun
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Re: A/C woes
Postby mhuppertz » Thu Jun 27, 2013 4:16 pm
105 degrees today in Albuquerque, new record.
mhuppertz
Re: A/C woes
Postby mhuppertz » Thu Jun 27, 2013 6:21 pm
I ended up doing this to work around it. Something is up within the PCM, and I don't have a logic chart of the PCM function to figure out the exact issue.
mhuppertz
Re: A/C woes
Postby mhuppertz » Fri Jun 28, 2013 8:13 am
Of course I simplified the schematic where possible.
I hate to leave it hacked like this, but the issue is a poor ground either in the wires to and from the PCM or in the PCM itself.
The compressor is working perfectly now, cycling as normal.
mhuppertz
Re: A/C woes
Postby Diesel » Sun Jun 30, 2013 2:36 pm
Wow that was tough
1991.5 D250 Intercooled A518
Diesel
Re: A/C woes
Postby Diesel » Thu Jul 11, 2013 12:52 pm
Well now its my trucks turn :/ Everything was fine and dandy and then today the compressor clutch is no longer engaged. Has a charge. I am guessing the compressor or clutch bit it? Too hot to do any testing and I am tempted to just put a new compressor on it anyway... Any tips for me to figure out what is broken?
Diesel
Re: A/C woes
Postby PToombs » Tue Jul 16, 2013 11:56 am
Just put power to the clutch and see if it kicks in or not. Simple test.
Users browsing this forum: No registered users and 72 guests
