Tacoclaw wrote:Much like injector threads, the majority of political threads are based mostly on hearsay and assumptions.
Let's start with this............... I called you hopeless........not worthless. No one is worthless.
The injector information I HAVE is not hearsay. 99% of the people who argue with what I say, is hearsay.
The reason I said you were hopeless is because I would answer your question and then 2 posts later you would bring up the exact same question. again and again...........that makes a pointless convesation.
Now to answer that again...........I was the first one to bring up that the main problem with comparing injectors is not comparing apples to apples, but comparing different sized sticks and pop pressures.
Only two things are needed to compare ACTUAL flow in lpm or fluid (fluid can be better)(mainly because it takes some of the guess work out)(even though it is not fully needed)(that's why I challenged Jacob Kidd to compare and I'll test it, and he wont' respond now)
The other is pop pressure.
Now, when I compare I look at all of the variables that are given to me. 99% of the internet people who jump in on an argument see 1 or 2 things and assume the rest and argue about the rest.
Now.........you brought up the point of matching flow...............I was the first to bring up that the flow is different between overall size.
That is because of the fluid dynamics and pressure changes in changing fluid forms.........in which you had to argue about, when brought back up to try and prove another point, which just made a circle.
This is becoming pointless again because all you are wanting to do is argue and make a big issue and not look at or read anything that anyone is actually saying.
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
