I'm pretty sure this is straight forward but better safe than sorry. Also, I've never really found any threads specifically addressing the oil lines with pictures so maybe this can become an informative post for someone else once I'm done with the installation.
My question is: which openings are the oil lines? On this side I believe I use the smaller one next to the wires as the inlet correct? I'm guessing the other is a water line for the factory electronics? (pic below)
On this side (the bottom) I use the odd shaped hole with the bolt holes above and below correct? do any of the openings need to be plugged, they're just water ports correct, ports I will not use and can just leave alone, open, untouched? (pic below)
If I'm not mistaken all the factory oil lines on my 93 w250 should be the same, no custom lines needed. If anyone knows otherwise please let me know!
