Greenleaf wrote:The coolant typer coolers; mount a Thermo-King in the bed to chill the water and route that throught the cooler.
Hook your A/C up to keep it cool, you know you'll have it on anyway!
90firstgen wrote: Once I get the water cooler, I'm gonna get some kind of reservoir, a small ricer radiator, and a ricer electric fan (out of junkyards of course) and mount the reservoir under the hood while the radiator and fan will be under the bed somewhere out of the way.
90firstgen wrote:Well I would definately have a decent sized pump to keep the water flowing. A big electric fan, like found on a ricer radiator, will be plenty to keep the water in the aftercooler cool. I'm very sure this would be a better system than air to air coolers. More complex yes, but more efficient. For example, people in professional racing run air to water coolers and they fill the reservoir with ice. They can have intake charge air temps that are below the ambient temperature outside.. which allows them to run insane amounts of boost making a heck of a lot of power. I've got a book on this stuff and I can't give you the quotes on percentage right now becuz I dont remember, but the air to water is considerably more efficient. I definately see your points though and the constructive criticism is beneficial to me cuz it makes me think everything through more. So I do thank everyone for that! I believe there would be plenty of air flowing around the radiator if its underneath the bed, especially with a fan on it. These things are made to keep gassers cool and I think the 5-10 psi of boost on the highway wouldnt overload it with heat. The amount of surface area per say of water wouldnt have to be the same as the amount of air it would take to cool the charge air because the water absorbs the heat better. Man all this talking really makes me want to get this project going!
Anyone got any leads on an air to water aftercooler
