cummins king wrote:im not worryed about pressure the idea it to flow the fuel so the ve keeps cool,
Ok, what does that have to do with return lines?????cummins king wrote:FORD is running huge injectors to move the fuel, so instead of filling your tank every pass,
cummins king wrote:because you cant burn all the fuel and its all going out the tail pipe
cummins king wrote:make the returns bigger so it will still move the fuel and not lose eficcienty and it wont blow so much black smoke
Not worried about pressure? Then how do you expect the rotor to get filled with fuel
Huh?? He can't burn all his fuel because he doesn't have enough air to do so
There was a time when some injectors didn't have a return, just a high pressure line. Black smoke is from not enough air and big injectors. Honestly there shouldn't be anymore fuel bypassing the nozzle than there is on a stock fuel system.
Users browsing this forum: No registered users and 79 guests
