85 F350 Crew Cab 4WD 12V Swap
Re: 85 F350 Crew Cab 4WD 12V Swap
Postby GPSMatt » Thu Aug 22, 2013 10:18 pm
oldestof11 wrote:Not to be a downer but that ZF5 is a better trans than the NV4500...
Hmm Ive had Zf5 issues in IDI's before. I feel the NV4500 well stand up better.
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Thu Aug 22, 2013 10:22 pm
Damn looks like facebook does not let you hot link pictures any more . I will go through and fix all the picture links.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby dazedandconfused » Fri Aug 23, 2013 4:08 am
The later ZF5 that came behind the PSD was smoother. I'm not a big fan of the NV4500. I've killed to many of them.
Postby GPSMatt » Fri Aug 23, 2013 9:14 am
ZF5s out of power strokes shake and rattle at idle without the dual mass flywheel.
http://www.youtube.com/watch?v=Ww-AfB8_M4M
That is the above Zf5 out of a power stroke that originally had a dual mass here it is in my 86 single cab 6.9 with single mass fly wheel.
I had an 88 with a factory Zf5 single mass fly did not do that at all. Parted that truck out and swapped it into my other 86 and ran it till it ground 2nd and 3rd
http://www.youtube.com/watch?v=sG6vkstBFP8
Bad example of a video lol but the 88 Zf5 did not do that hole stupid vibrate with clutch out in neutral thing.
My Zf5 storys dont end there..
What kind of issues have you had with the 4500?
I picked mine up for $500 rebuilt 5th gear issue fixed.
One thing about the 4500behind a cummins in a ford I dont like is the shifter is kind of far back
The zf5 shifter is in the same position as the t19 shifter would go.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby dazedandconfused » Fri Aug 23, 2013 12:24 pm
We just struggle to keep them together. They are slow, hard shifting dam transmissions. We have ate tons of them up in a one ton Chevy behind a small block. I've had great luck with the ZF5 myself.
Postby CumminsPower59 » Fri Aug 23, 2013 3:29 pm
I haven't had too much experience with NV4500's, but I like the shorter, smoother shifting compared to the Getrag...I guess its hit and miss with durability.
Postby dazedandconfused » Fri Aug 23, 2013 3:42 pm
I've ate two behind Cummins trucks, dad ate several behind s small block Chevy and I ate another in a 3500hd Chevy behind a 454. I have just found they don't like to be worked hard, but we probably work them harder then most.
Postby ellis93 » Fri Aug 23, 2013 6:02 pm
Andy most of the Chevy 4500's were not deserving of there trans noted reliability. Most were,imho,inferior units.
As far as I know a ZF5 was a ZF5 unit with exception of the outputs and associated housings
Postby dazedandconfused » Fri Aug 23, 2013 6:18 pm
They lasted longer then the diesel versions I ate up and spit out. I'm just not a fan of them I guess. From what I've gathered the newer ZF trans had update synchros and a few little updates. That's only what I've read though and never been in one. I know I beat the ever living piss out of one and never missed a beat.
Postby GPSMatt » Wed Aug 28, 2013 10:47 am
Good info it gives me something more to think about. I have changed plans on this truck so many times I just want to get it done because its super close. IF anything I will swap in an auto. I got a smoking deal on a 5R110 out of an 07 6.4 when I wanted to pull out the cummins and do a 6.4 swap for a quick minute. I am now planning on doing that to the single cab but have been looking at the destroked 5r110 adapter plate and controller to run behind this motor.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Mon Sep 02, 2013 2:02 am
Next on the list is finishing I/c pipes
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Mon Sep 02, 2013 1:36 pm
One of the big reasons the project got held up for so long is I have a friend who builds turbos and has a machine shop so I had him put a 62mm wheel in my originally 58mm super B. I coudnt decide if I wanted to do fire ring or O ring and ended up just doing new HG with ARP's.
Another turbo he built for me for my mustang
Its a K31 frame with a machined S300 ex housing .91 ar 76mm ex wheel 71mm billet compressor wheel. Basically an aurora 5000. Once I build new motor for the mustang going to an S480 on that and I want to use this on the truck with the S300 and do compound.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby Knoberman » Wed Sep 18, 2013 6:49 pm
What are you doing for an intercooler?
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
