Project ugly duckling
Re: Project ugly duckling
Postby PToombs » Wed Sep 11, 2013 4:12 pm
It's your lie, tell it however you want! :lol:
Andy, the front round bar is welded to a flat plate which is bolted in. (notice the tabs welded on to put the strap bolts thru) I can't remember if the rear angle iron is welded to the frame or welded to plates and bolted.
Postby dazedandconfused » Wed Sep 11, 2013 5:45 pm
Thanks Pete I figured it wouldn't be super hard. Need to figure my trans out before I mess with the tank.
Postby ellis93 » Wed Sep 11, 2013 5:55 pm
Andy,if you use the pressure switches to actuate the o/d & l/u,buy Hobbs switches that are adjustable above 55psi if you intend to Jack with the line pressure. I'm having to deal with this now.
Postby dazedandconfused » Wed Sep 11, 2013 6:05 pm
I'm going to leave of setup the way it is now and run a switch to control lockup once I swap over. Right now my 518 decided to start bleeding out of both ends.
Postby ellis93 » Wed Sep 11, 2013 6:19 pm
Did you check the vent? Could be building pressure.
Postby PToombs » Thu Sep 12, 2013 4:37 pm
dazedandconfused wrote:my 518 decided to start bleeding ..............
Taco wasn't over visiting lately was he? :lol:
Postby dazedandconfused » Thu Sep 12, 2013 4:51 pm
Yeah vent is fine. This may kill me making it to sop again.
Postby ellis93 » Thu Sep 12, 2013 4:53 pm
Well that sucks :?
Postby cmann250 » Thu Sep 12, 2013 5:19 pm
dazedandconfused wrote:Yeah vent is fine. This may kill me making it to sop again.
NOOOOOOOOOOOO!!!!!! :mad: :mad: :mad:
Postby dazedandconfused » Fri Sep 13, 2013 3:49 am
Its irritating it just decided to start flowing out each end at the same time. My buddy said its on the rag. lol
Postby dazedandconfused » Fri Sep 13, 2013 1:54 pm
So I'm going to try and get a new driveshaft made and see if it will stop the vibration I have and hope the rear seal stops working its way out.
Postby dazedandconfused » Sun Sep 22, 2013 2:18 pm
New seat.
Postby CumminsPower59 » Mon Sep 23, 2013 3:34 pm
Pretty comfy? How's the leg room?
Postby PToombs » Mon Sep 23, 2013 3:57 pm
CumminsPower59 wrote:Pretty comfy? How's the leg room?
I was wondering the same. I know how mine is, I figure yours is gonna be a tight fit.
Postby dazedandconfused » Mon Sep 23, 2013 5:29 pm
Leg room is the same as more. I wish I could have got it down just a little more so the seat back would go where the other seat was. I kept it as low as possible and cut up the factory seat frame. The seat bottom can physically not go any further back or down. I need to do some pondering. If I could get it 1/2" to an inch lower it would tuck back in the cab like my old seat did without the head rest.
Users browsing this forum: No registered users and 68 guests
