Postby CumminsPower59 » Tue Sep 17, 2013 5:01 am
Bahahahaha!!!!!! :lol: :lol:
Postby CumminsPower59 » Tue Sep 17, 2013 10:27 am
Well, so much for pulling up the head bolts. Got to number 22 in sequence, snap! What now? :mad:
Postby CumminsPower59 » Tue Sep 17, 2013 10:41 am
Crap :(
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:51 am, edited 1 time in total.
Postby ellis93 » Tue Sep 17, 2013 11:28 am
Some beach.....some where :(
Postby CumminsPower59 » Tue Sep 17, 2013 11:39 am
My inner cheapness says pull the head, fish that busted bolt out, clean the block and head surface, slap a new head gasket and bolts on and go...buuuut, I really want a new head, studs, etc...
Postby Tacoclaw » Tue Sep 17, 2013 12:10 pm
Damn, my inner cheapness said torque the ones around it extra-tight and run it until there's a problem. :lol:
Postby dazedandconfused » Tue Sep 17, 2013 12:31 pm
I'd do like you just said Ike.
Postby CumminsPower59 » Tue Sep 17, 2013 1:22 pm
Taco, I torqued all of them up to 125, except the one betweem cylinder 2 and 3, it kinda got tighter then kept turning, so I stopped. I'm sure I pulled the threads on that one...
Postby RumbleFish » Tue Sep 17, 2013 1:40 pm
Fuuuuuuu.....
Postby ellis93 » Tue Sep 17, 2013 2:07 pm
Put a new head on an old bottom,when the other is working fine? Not me :lol:
I'd find bolts or studs and a gasket set....then get er done
Postby CumminsPower59 » Tue Sep 17, 2013 2:09 pm
Fixin to pull the trigger on a Victor/Reinz Gasket set...any nay sayers?
Postby ellis93 » Tue Sep 17, 2013 2:12 pm
Not from me,it's what I'd have to run and have. I think Pete said at one time he has one on his truck now.
Postby CumminsPower59 » Tue Sep 17, 2013 2:15 pm
Right on! Done! I guess the hard part will be getting that chunk of bolt out of the block...on the bright side, it's in an easy spot to get to :lol:
Postby Tacoclaw » Tue Sep 17, 2013 3:17 pm
CumminsPower59 wrote:Taco, I torqued all of them up to 125, except the one betweem cylinder 2 and 3, it kinda got tighter then kept turning, so I stopped. I'm sure I pulled the threads on that one...
I'd bet you just stretched the bolt, unless the threads were boogered up previously I don't think there's any way you messed them up.
Postby CumminsPower59 » Tue Sep 17, 2013 3:25 pm
I'm hoping that is the case. I am on the hunt now for a M12x1.75 bottom tap...
