cmann250 wrote:Ok, this is as close to a venting thread as I'm going to get.
Strike two- the old electric start flywheel had to be used on the new engine. This is a problem because the key and crank throw don't line up.:
ellis93 wrote:Any chance that there are other bosses for the coil cast into the block?
Tacoclaw wrote:You could have a keyway cut 180* on that flywheel, shouldn't be too expensive at a machine shop.
