newer engine with ve pump ?
Postby burnt_servo » Mon Jan 21, 2008 2:24 pm
i have a chance to get my hands on a newer 4bt engine , cheap , the same style the 24 valve engine .
there is no engine computer , can a ve pump be fitted to a 24 valve engine , and by extension , the 4 cylinder version , and still have it work well .
or at least as well as the older 12 valve ( or 8 valve for the 4cyl ) version of this engine .
i'm thinking of a vw ve pump wth a 12mm head .
or do i have to do a head swap to make this work ?
burnt_servo
Postby meby » Tue Jan 22, 2008 9:55 am
You should be able to do this. I would think the process would be similar to retrofitting a VE powered engine P7100. New or custom injector lines. changing the gear housing. and possibly some head modifications? I just finished class so I cant really think this through. Guys, correct me? :)
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby g1625s » Sun Jan 27, 2008 6:17 pm
VE=3-bolt mount, p-pump and VP are 4-bolt mount. You'd need a timing case and pump gear...and injectors and lines...
presently-'96 4x4 2500
formerly-'89 W350
g1625s
Postby roxxx » Mon Jan 28, 2008 10:48 am
woo that would be a load of money to change the 24 Valve to a ve pump the head would have to except the lower pop off injectors of a first gen motor
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Re: newer engine with ve pump ?
Postby studlybilly » Tue Jan 29, 2008 2:21 pm
burnt_servo wrote:i have a chance to get my hands on a newer 4bt engine , cheap , the same style the 24 valve engine .
I have a VE pumped 4bt and would swap everything with ya. The P Pump is more desired for what I intend to do.
98 Durango "High Class Hooptie" - rockwells, 53's, 4 wheel steer.
studlybilly
Postby burnt_servo » Tue Jan 29, 2008 6:44 pm
this isn't a p pump engine , if it was i'd be laughing and the engine would be sitting in my basement .
it's a vp44 , same as the 24 valve dodges , except there is no engine controller ( ie computer ) .
burnt_servo
Postby cummins king » Tue Jan 29, 2008 8:17 pm
ebay has lots of p pump 4cly
93 4X4 auto
cummins king
Postby PToombs » Wed Jan 30, 2008 4:26 pm
Check junkyards for heavy equipment. Case backhoes have 4bts with p-pumps. The hp might be lower than a bread truck, but I think you can fix that. ;) :jumpsmile:
