How are most folks doing crew cabs
Postby Dodgecrawler2011 » Thu Oct 03, 2013 8:04 am
Kinda been looking around seems to go both ways. Are people putting the cummins drivetrain in a gas motor truck or modifying the cummins frame. What are pros and cons to both and differences in the frames. Looking at doing a crew cab short bed
Dodgecrawler2011
Re: How are most folks doing crew cabs
Postby RCCUMMINS89 » Thu Oct 03, 2013 12:41 pm
A crew cab frame is plenty strong enough.........just make sure you're running a dana 60 up front and you're good.
If you're like me.........you simply put the crew cab frame on whatever you have and then run a flat bed. My dad has an 85 crew cab on a 91 std. cab frame.......works out to be a 5' flatbed. We did it that way because swapping bodies is a lot easier than swapping everything else over and the short wheelbase is nice up here in the mountains. (hence why I built an RC)
Postby rb70383 » Thu Oct 17, 2013 2:21 am
I am converting mine to 4wd and putting a Cummins in it. Also mounting a utility bed on the back. Have to move the rear axle back about 4-5" since the bed is for a 60" ca.
rb70383
Postby bmoeller » Sat Jan 18, 2014 12:52 am
Mine started as a 2wd dually. Now has a Cummins, 6spd, 60 front/80 rear, 205. Bought a 93 donor truck and cut part of the front frame section off of the donor to make templates to make and drill the holes for the 4wd front end. Also used the the front 4wd crossmember and engine crossmember. Modded the stock trans member for the 6spd and used a 2nd gen trans mount.
Pulling the dually bed, for a good used aluminum flatbed and 7" stacks off of a Pete. lol
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby draginmopars » Sat Jan 18, 2014 2:54 pm
due to being a car hauler
we put the cummins in the crew frame
and with rust removal, married a 92 club cab (Cummins)
to the 73 gas cab, added the LE package
now, looks factory, under the hood
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Sat Jan 18, 2014 4:27 pm
Draginmopars have you finished yours yet? I haven't seen any updates on your thread.
Postby draginmopars » Sat Jan 18, 2014 4:46 pm
dazedandconfused wrote:Draginmopars have you finished yours yet? I haven't seen any updates on your thread.
health reasons- slow me down ( smashed my foot)
then, got into building a race car for Gayle
We will be back to working on it this spring
wiring/ paint
Thanks for the interest
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby dazedandconfused » Sat Jan 18, 2014 4:50 pm
I was hoping you hadn't gave up on it.
Postby draginmopars » Sat Jan 18, 2014 5:07 pm
dazedandconfused wrote:I was hoping you hadn't gave up on it.
Naw, gone to far to quit now.. :lol:
cab is back on
just a few wires for the cruise and a/c
and head light relays
then paint/ tires
All the big maintence items are taken care of eng/trans , brakes and steering.
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby CAJUN 93 » Sat Jan 18, 2014 8:23 pm
I've got a 93 w350 std cab and a 93 d350 ext cab frame that I'm cutting and splicing to make a w350 8 ft bed dually. I have a 96 dually that the p-pump engine, 47re converted to rh and dana 80 rear are coming out of. I'm also using the wiring harnesses, dual batteries, a/c system and radiator-intercooler out of. I removed the whole radiator support from the 96 and cut the 93 support to splice together. Lots of work but I only plan on doing it once.
Daryl
CAJUN 93
Postby PToombs » Sun Jan 19, 2014 5:09 pm
Wow Daryl, no wonder you don't post much anymore, the wife has you chained in the garage! :shock:
Postby CAJUN 93 » Sun Jan 19, 2014 6:12 pm
Lol, that's about right. Actually I'm here almost every night but I don't post much. I'm more of a casual observer.
CAJUN 93
Postby superbeemike » Sat Feb 08, 2014 9:05 am
I used the 85' Crew's frame, body, and sheet metal. I just switched in all the guts from a 92' that was wrecked. It was easier than I thought and works great. 20k+ miles since it was completed. I will be converting it to 4wd in the future which doesn't appear to be too complicated.
Mike
1985 D-350 Crew Cab SE Royal Prospector, 92CTD/A-518
superbeemike
Postby CumminsPower59 » Sat Feb 08, 2014 9:11 am
That is one clean crew cab. Very nice :thumright:
