Rear axle brake line
Postby 93 W350 LE » Sat Oct 12, 2013 3:07 pm
So, replacing the wheel cylender. I twisted off the frozen fitting. Should I just go ahead and replace both sides? Pre made or bend and flare my own?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: Rear axle brake line
Postby CumminsPower59 » Sat Oct 12, 2013 6:23 pm
In my recent experience with dealing with rusty brake lines...replace them all. All the hard lines on my 91 are parts store type "sticks". I just routed them as same as the old ones, and if they were too long, I put a loop in them.
Postby 93 W350 LE » Mon Oct 14, 2013 4:19 am
Got 6' of new line and bent it up. Took a couple trys to get good double flairs though. Good thing I cut long.
Eric
93 W350 LE
Postby skilletky » Mon Oct 14, 2013 5:58 am
bypass the abs valve, replaced all the rubber lines, and buy a good(not autozone) master cylinder. i did this, and my brakes work as good, if not better, than my 01.
skilletky
Postby 93 W350 LE » Sat Oct 19, 2013 4:06 pm
Got the fittings for the ABS delete when I got the other brake parts.
Eric
93 W350 LE
