1st 2nd gen INJECTORS
Postby fasttalker83 » Sun Jan 27, 2008 9:50 pm
Hey guys probably a stupid question but can you take the tip off of a 2nd gen injector and put it into a 1st injector body have found 90hp 2nd gen injectors I would just like to take the tips off and put them on my 1st gen bodys any help would be appreciated
fasttalker83
Postby ford69557ci » Sun Jan 27, 2008 10:08 pm
you can but the pressures will have to be reset and if your truck is non ic then you will need to purchase 7mm to 9mm adapters
ford69557ci
Postby Philip » Sun Jan 27, 2008 11:40 pm
The spray angles are different on the 2nd gen tips also. You might have smoke issues.
Postby ford69557ci » Sun Jan 27, 2008 11:51 pm
with sticks as small as the 90hp ones there will be no issues. Get into somethin larger like a 435 or pod's and there could be a problem
ford69557ci
Postby JD730 » Mon Jan 28, 2008 6:02 am
Do yourself a favor and see if you can find out what size and how many holes there are. Don't be surprised if its the same size or not much bigger than the stock nozzles.
Mike
The "Rattle Box"
JD730
Postby cummins king » Mon Jan 28, 2008 6:43 am
and i dont know how much you paying for them but for the size you want you can buy new ones for first gen for a few hunderd and the pop pressure are right and everything
93 4X4 auto
cummins king
Postby ford69557ci » Mon Jan 28, 2008 12:19 pm
I agree with that talk to Chuck at New Era last i checked you could get a set of 435's set up correctly for our engines for like 500 or under.
Dodge 12V
300's $360.00
330's $380.00
370's $400.00
435's $490.00
HOT!!! ANY SIZE OR SPECIAL SPRAY PATTERN $700.00
ford69557ci
Postby fasttalker83 » Mon Jan 28, 2008 2:31 pm
I can get a set of this for a 2nd gen no cores new injectors 90hp for 205.00 plus shipping thought it was a kick ass deal
fasttalker83
Postby CumminsPride » Mon Jan 28, 2008 2:56 pm
So is the pop pressure set by the torque setting of the body?? The nut that holds the tip to the body is this the pop setting?
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby fasttalker83 » Mon Jan 28, 2008 5:08 pm
I dont know I have a pop tester and can set them to anything I want and I have a flow bench to match a modded pump for best results I have been told that standard is like 3800 but need to set pressure up to 4200 when putting these on a the 1st gen body beats me really im just goin by what the local shop told me
fasttalker83
Postby ford69557ci » Mon Jan 28, 2008 5:18 pm
the 1st gen sticks have lower pop setting and there are shims to set the correct pressures. tryin to run p pump pressures will be the end of you ve pumps h&r
ford69557ci
Postby CumminsPride » Mon Jan 28, 2008 7:15 pm
fasttalker83 wrote:I dont know I have a pop tester and can set them to anything I want and I have a flow bench to match a modded pump for best results I have been told that standard is like 3800 but need to set pressure up to 4200 when putting these on a the 1st gen body beats me really im just goin by what the local shop told me
If you can set them to anything you want then how is the pop pressure adjusted?? Is there true science to changing tips. And what does the nozzle and needle have to do with POP pressure?? I thought the BODY was set to a PSI or BAR then the nozzle was installed. I don't know so an education may be in order. Thanks
CumminsPride
Postby cummins king » Mon Jan 28, 2008 7:51 pm
let me guess Pensacola Diesel
:puker:
i think that says it all
you dont get nothing good for 205
93 4X4 auto
cummins king
Postby fasttalker83 » Sun Feb 24, 2008 3:25 pm
acutally yes they were coming from pensacola diesel but instead I went out and like a big boy just spent 430.00 at shceid in effingham (closest) on just the tips alone then spent another 42.00 on some copper gaskets ya I think I got my A$$ handed to me that day and the whole thing on the pressure setting is yes the standard is 3800 psi if you go 100hp or bigger you set it at 4200psi the pressure is set by one or more shimms usually more if you go up in pressure inside the injector body above the spring that pops off the needle in the tip if you have a very fine (small) shimm you want to put it on the bottom side of the spring so your injector dont beat the living crap out of it and as long as you can get all your injectors to pop off at 100psi in range of each other your all good and ready to go learned alot last week in class...lol ya and if anyone can get me some shimms like a variety of them I would appreciate since shceid wants 1.00 a piece for them and no one else can get them not unless you have DT466 injectors laying around they are the same shimm
fasttalker83
Postby cummins king » Sun Feb 24, 2008 3:28 pm
that a boy, its better to spend the money once
93 4X4 auto
cummins king
