Cummins Excursion
Re: Fummins project
Postby CumminsPower59 » Thu Nov 07, 2013 9:14 am
^^^^ I second that!
Re: Fummins project
Postby dazedandconfused » Thu Nov 07, 2013 9:16 am
Sounds like Chris is donating an engine to me. :lol:
Re: Fummins project
Postby skilletky » Thu Nov 07, 2013 9:47 am
for a small fee of course :lol: ill sell ya the one from the black truck. its about to get gone here soon probably.
skilletky
Re: Fummins project
Postby dazedandconfused » Sat Nov 09, 2013 4:46 pm
So I did a little to the Ford today. I pulled the passenger side fender and bed off. I then pressure washed everything. The previous owner replaced all the brake lines, booster tank, master cylinder, calipers, fuel lines and painted the back of the frame. The bed has a couple dents but no rust. I'm going to paint all the frame, bottom side of the bed, cab and core support with chassis saver.
I'm going to paint it 2 tone blue like my old Ford.
Re: Fummins project
Postby dazedandconfused » Sun Nov 17, 2013 11:16 am
Well I worked on it a bit yesterday. I finally got it all apart so now its time to start working on cab mounts. I've priced some motor mounts and a few other parts.
Re: Fummins project
Postby CumminsPower59 » Mon Nov 18, 2013 3:55 pm
Semi float rear axle??? :puker:
Re: Fummins project
Postby dazedandconfused » Mon Nov 18, 2013 5:58 pm
Yeah it will work for now though.
Re: Fummins project
Postby ellis93 » Mon Nov 18, 2013 7:33 pm
dazedandconfused wrote:Yeah it will work for now though.
I may be able to "hook" you up again :lol:
Re: Fummins project
Postby dazedandconfused » Fri Nov 29, 2013 12:47 pm
Well did a little bit of work today to the truck. I pulled the doors off and was able to get some help to lay it on its back. The front cab mounts are gone and part of the front floor pan is rotted. I'm going to pressure wash the bottom side when I can get the garden hose thawed out.
Re: Fummins project
Postby PToombs » Fri Nov 29, 2013 3:30 pm
Buddy, that's not any better than a Dodge cab! :lol:
Re: Fummins project
Postby dazedandconfused » Fri Nov 29, 2013 3:48 pm
No but I can purchase all the panels unlike a Dodge Cab. Not to mention there are a few in the local junkyard. Pressure washed off the bottom. Its pretty solid other then the front two mounts.
Re: Fummins project
Postby PToombs » Sat Nov 30, 2013 5:20 pm
Amazing what a wash will do, looks better already!
Re: Fummins project
Postby dazedandconfused » Sat Nov 30, 2013 5:24 pm
It had this nasty ass mud that looked like rust. Its the main reason I pulled the cab instead of just lifting to do the repairs.
Re: Fummins project
Postby dazedandconfused » Mon Dec 09, 2013 3:49 pm
So I found a cheap rusty F350 Powerstroke I'm going to go look at. May use that as a donor and keep the duck the way it is.
Re: Fummins project
Postby cmann250 » Mon Dec 09, 2013 4:30 pm
Now it is perfectly clear why we get along so well :lol:
