Brake pedal gets hard
Postby 93 W350 LE » Sat Dec 07, 2013 6:43 pm
My brake pedal gets hard if I am on it for more than a few seconds. Like when you lose power and try braking. Seems like I am losing vacuum or something. Any ideas?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: Brake pedal gets hard
Postby PToombs » Sat Dec 07, 2013 7:11 pm
Tee in a vacuum gauge and see what it's doing. You should have about 22-23 inches of vacuum at idle to begin with. It sounds like the booster may be bad and leaking, but the pump could be getting weak too.
Postby ellis93 » Sat Dec 07, 2013 7:27 pm
Mine does the same....when its cold out. Booster has a seal on the inside rod that shrinks and let's the vacuum pass by,that's what the deal is with mine. I'd have fixed it but those that have bought reman boosters have had schity luck gettinga good one,so I deal with it.
Postby 93 W350 LE » Sun Dec 08, 2013 8:41 am
It has happened since leaving Fl and coming to winter in Northern Okla. My brake and abs lights will come on if on pedal too long, but go back off as soon as engine speed goes up. The pedal also softens up if released for a couple .seconds.
Eric
93 W350 LE
Postby Tacoclaw » Sun Dec 08, 2013 12:12 pm
That little sensor over by your driver's hood hinge is a vacuum sensor, if it senses low vacuum it'll turn your brake light on.
