Project ugly duckling
Re: Project ugly duckling
Postby ellis93 » Fri Nov 22, 2013 6:53 pm
Pete,that isn't the first time I've did that either..... :lol: It works,believe it or not. It will stay there till I have a decent one built for the 12bolt I put in it ;)
Postby dazedandconfused » Sun Jan 05, 2014 12:12 pm
Well I went out to move the Duck the other night and she won't budge. I don't know if the hydro oil had thickened up that much even though its a quart low or the 518 just gave up. I figure I'll have about a grand rebuilding it.
Postby cmann250 » Sun Jan 05, 2014 12:36 pm
dazedandconfused wrote:Well I went out to move the Duck the other night and she won't budge. I don't know if the hydro oil had thickened up that much even though its a quart low or the 518 just gave up. I figure I'll have about a grand rebuilding it.
I'm at 100% hydro oil and I don't have any issues. RIP poor 518.
Who's parts are you going to use?
Postby Remps » Sun Jan 05, 2014 12:37 pm
Do you have a magnet heater you could stick to the trans pan? Did you let it run in neutral for a while to circulate the fluid?
Postby dazedandconfused » Sun Jan 05, 2014 12:51 pm
Yeah I let her run in neutral for about 10 minutes. Caleb I think I'm going to use a Transfer master kit, trans go shift kit and a Spec rite Tq convertor. Ill probably upgrade to the Sonnax Billet Aluminum 4 Ring Accumulator Piston, Sonnax 16% Oversize Intermediate Servo with Cover and the Power Wedge Intermediate Band Anchor and 4.2 apply lever. Has anyone ran the Fairbanks shift kit?
Postby Tacoclaw » Sun Jan 05, 2014 2:04 pm
Frozen brakes by any chance?
Postby dazedandconfused » Sun Jan 05, 2014 2:09 pm
No she won't even try to move. I pulled it up the driveway with the Ford then rolled it over by the house. I'll mess with it when its not raining and freezing out.
Postby PToombs » Sun Jan 05, 2014 4:20 pm
Andy, have you ever seen the Sonnax book? I have one, don't remember where I got it. It has all the fixes and part numbers for almost any trans out there, loose and worn bores, a reamer and oversized spools to fit, different springs, bands or what ever else may be wrong with it. Pretty handy to be able to look and see the common problems and what the fix for it is. And have the part numbers for the better parts and tools if needed.
Postby dazedandconfused » Sun Jan 05, 2014 4:30 pm
No but I saw the son ax fix kit or whatever its called on Patc I believe. It was like $150 and fixes all the issues it said. I'm thinking she is really low on fluid judging by the puddle under it. No matter what it needs fixed. The sop trip took its toll on her.
Postby cmann250 » Sun Jan 05, 2014 5:10 pm
If you don't have a rebuild manual, I have an ASTG book that I could loan you.
Postby dazedandconfused » Sun Jan 05, 2014 5:12 pm
I have one floating around here someplace. I had a DVD of a rebuild somewhere too but who knows where that went.
Postby dazedandconfused » Mon Jan 06, 2014 9:45 am
So went out and started her today. Let it idle in neutral and she moved its just really low on fluid.
http://s606.photobucket.com/user/dazeda ... 9.mp4.html
Last edited by dazedandconfused on Mon Jan 06, 2014 10:19 am, edited 1 time in total.
Postby cmann250 » Mon Jan 06, 2014 10:15 am
Can't kill a Loadflight :D
Good to hear that it's not completely toast.
Postby dazedandconfused » Tue Mar 11, 2014 2:27 pm
So Im back to driving the Duck. I patched up my u-joint and stopped today to have a new shaft made. I think I'm getting the shaft too since they quoted me around $400 for that little driveshaft.
Postby ellis93 » Tue Mar 11, 2014 4:25 pm
Mother of god......those folks command a price don't they. I've never paid that much for that short of a shaft.
