Lift pump lever???
Lift pump lever???
Postby hassy21 » Mon Feb 04, 2008 11:07 pm
On the lift pump it has a lever on the bottom of it and was wondering what that does and where it should be positioned?
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby ford69557ci » Mon Feb 04, 2008 11:30 pm
it is a primer pump for if you run outa fuel or have to change the filter ans my old one locked in the up position
ford69557ci
