usb turbo
Re: usb turbo
Postby brandonmgreer » Thu Oct 10, 2013 10:58 am
:? OK, really dumb queation, but what is IIRC? so I'm not in the dark anymore
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Re: usb turbo
Postby CumminsPower59 » Thu Oct 10, 2013 11:41 am
If I Remember Correctly
Re: usb turbo
Postby brandonmgreer » Thu Oct 10, 2013 12:04 pm
OK... I'm still learning all the text abbreviations as well. Thank you
brandonmgreer
Re: usb turbo
Postby CumminsPower59 » Thu Oct 10, 2013 3:40 pm
You're welcome.
Re: usb turbo
Postby RCCUMMINS89 » Thu Oct 10, 2013 4:18 pm
brandonmgreer wrote::? OK, really dumb queation, but what is IIRC? so I'm not in the dark anymore
It's ok, I have to google abbreviations almost daily. :D
Re: usb turbo
Postby Sutter1stgen » Fri Oct 11, 2013 9:45 am
Certain foods cause me to suffer from iirc.
(irrational, irregular, rectal, control)
Eric
Sutter1stgen
Re: usb turbo
Postby AHineman » Fri Oct 11, 2013 10:04 am
Re: usb turbo
Postby PToombs » Fri Oct 11, 2013 6:00 pm
Eric, that's a sign of old age. ;)
Re: usb turbo
Postby RCCUMMINS89 » Fri Oct 11, 2013 8:30 pm
I've been told I have shown my age twice now in 2 days.
Re: usb turbo
Postby JQmile » Fri Oct 11, 2013 9:44 pm
Sutter1stgen wrote:^^^^ your right. "blueprints for torque". It's actually the only issue I've lost, and it had a bunch of cool basic recipes.
It's still online, just hard to find. Has almost all the original West Coast OG's...Kat, Ponci, Drake, Chris, Cole, Joe, Adam, Erick, etc.....one of my favorite articles, also how Erick and I became buddies.
http://www.dieselpowermag.com/features/ ... ewall.html
JQmile
Re: usb turbo
Postby Deathrod » Fri Oct 11, 2013 9:59 pm
Pretty cool read.......don't know how I missed that one!!!
Deathrod
Re: usb turbo
Postby JQmile » Fri Oct 11, 2013 10:12 pm
How you been? Working tomorrow night??
JQmile
Re: usb turbo
Postby Deathrod » Sun Oct 13, 2013 6:36 pm
A little late but, yup I was workin last night. You weren't in the LBC were you????
Deathrod
Re: usb turbo
Postby dunes450r » Mon Oct 21, 2013 6:26 pm
the best part is, bell turbo is only 10 minutes from where i live! the only worth while place to go, he has thousands of turbos/parts just scattered around, hard to get ahold of sometimes too
dunes450r
Re: usb turbo
Postby Joecochrane » Fri Jan 17, 2014 10:17 pm
I've ran a 62/65/14 on my old truck and it was one fast spooling hard hitting sob. I plan on putting it on my ford as soon as I get more fuel to her hope it runs as good on the ve motor as it did on my 24v.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
