vent tube leak???
vent tube leak???
Postby hassy21 » Mon Feb 04, 2008 11:05 pm
I have a 90 dodge d-250 and it has been leaking out of the vent tube in the back of the injector pump. I was wondering how you would stop that?
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby Philip » Tue Feb 05, 2008 9:47 am
You need to pull the top off the injection pump and replace the O rings on the fuel pin.
Postby Begle1 » Tue Feb 05, 2008 12:58 pm
Isn't there only one ring on the fuel pin?
And how are you supposed to replace that one?
Postby cummins king » Tue Feb 05, 2008 6:15 pm
its quite easy to fix
you take the top off the pump, then you take the plug out of the back
that the diifam out and pin, then knock the pin out as far as it can the take an alean key and stick it in were the pin is and you should be able to unscrew the little alen ket thing that holds in the seal pull that out eplace seal and put back together
i havent done it in awhile so these instructions arnt the clearest but its very easy to do,
93 4X4 auto
cummins king
Postby 75Dodge » Tue Feb 05, 2008 8:15 pm
Hey dude just go here. This where I found the details to rebuild the top half of my pump. While you're in there you might want to replace the O-ring for the full load screw too.
http://www.dieseltruckresource.com/dev/ ... p?t=153154
75Dodge
Postby hassy21 » Wed Feb 06, 2008 12:35 pm
I have taken my afc oput and i thought with my afc gone the fuel pin doesnt even work so i just took it out and put a small bolt where the hole is. Do you think that the bolt is not sealing the hole good enough?
hassy21
Postby 75Dodge » Fri Feb 08, 2008 9:12 am
Possibly. You might want to put some liquid teflon on it and re-install it. Best thing is take some brake cleaner or carb cleaner spray off the top of the pump and then run it to find the leak.
75Dodge
Postby 75Dodge » Fri Feb 08, 2008 10:12 am
From there you can find out whether or not it is an o-ring or just the bolt.
75Dodge
Postby cummins king » Fri Feb 08, 2008 12:20 pm
with mine i ut an alen key plug in it then i put the insection plug back in i dint use any think for sealing but then again i cut my pump top off and taped a 1/2inch, hole for a gauge and dual feed
93 4X4 auto
cummins king
