1992gen1_fan wrote:U-joints look good, the drive shaft its self needs work though. Alot of play where the 2 pieces of the drive shaft meet.
m880cummins wrote:Check/replace U joints, check motor mounts and, if you have a 2 piece rear driveshaft check the carrier bearing for slop. Also if you have a suspension lift, make sure the two piece rear shaft is perfectly straight. You may have to make a spacer to drop the carrier bearing if it isn't.
Charlie
