okay im am positivaly
a few time stumped
okay this is my system as of tonight
1/2 inch pickup
to my aeromotive fuel filter,
1/2 inch line from my aeromotive fuel filter to my aeromotive fuel pump
then to my aeromotive regulator, then to a guage
the to a check valve then 1/2 inch to my ip ,
the bypass part on my regulator is 1/2 inch line back to the tank
the return for injectors and ip is stock
the truck will idle it will go through all the rpm's and then idle, it runs perfict,
But....... then i turn it off and and try to restart the truck wont start and waiting wont help,
before i started this morrning i checked the oil, its 1/2 way between the safe and add mark, and when i finished tonight its in the exact same spot
Pease Help
