where can I find a throttle shaft bushing for my IP?!
Postby gear jammer 91" » Thu Feb 07, 2008 9:51 pm
I just got my gasket kit for my IP and it came with everything I need except the f*cking throttle shaft bushing. fortunately for me that is where my leak is :mad: WTF! The part number on the kit is DGK121 I thought it was supposed to have this damn bushing but since it doesn't I need all the help I can get in trying to locate one of those things, and probably a couple valium so i can relax. I need my truck back on the road please help!
01 LB7
gear jammer 91"
Postby Philip » Thu Feb 07, 2008 10:19 pm
I got mine from Schied diesel. # 1469324332-000
I can't remember the price.
Postby gear jammer 91" » Fri Feb 08, 2008 7:31 am
Thanks for the part number :) I have just been informed that their is an o-ring on the throttle shaft, I'm gonna try just replacing it but if it still leaks I'm gonna have to get that bushing.
01 LB7
gear jammer 91"
Postby Philip » Fri Feb 08, 2008 8:58 am
I have been told by a reliable sourse that the throttle shaft also wears. If your doing the bushing to throw a shaft in also. I don't have a numbr for that one.
Postby PToombs » Fri Feb 08, 2008 6:22 pm
Is there a lot of play in the shaft? If not, just do the o-ring. The pump shop here likes to install the bushing and bake it in an oven to cure. Clear cut case of CYA. They wanna make sure the glue is set.
Postby gear jammer 91" » Sat Feb 09, 2008 9:54 am
I tore it apart last night. Their wasn't ant significant play in the shaft so I just installed a new o-ring, a new pump top gasket, and most importantly a 3200 rpm gov spring :P . The leak is gone and gov spring is the best money I've spent on the truck so far, It's loke turning the fuel screw in all over agin 8) .Thanks for all help everyone. :)
01 LB7
gear jammer 91"
Postby cummins king » Sat Feb 09, 2008 4:47 pm
i have two sitting on the self if anybody needs one, (throttle shaft bushing)
93 4X4 auto
cummins king
Postby BEARKILLER » Mon Feb 18, 2008 2:35 pm
gear jammer 91" wrote:I tore it apart last night. Their wasn't ant significant play in the shaft so I just installed a new o-ring, a new pump top gasket, and most importantly a 3200 rpm gov spring :P . The leak is gone and gov spring is the best money I've spent on the truck so far, It's loke turning the fuel screw in all over agin 8) .Thanks for all help everyone. :)
Did you do this with the pump still on the engine; or, did you have to remove the pump ??
Thanks.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby cummins king » Mon Feb 18, 2008 4:15 pm
you dont have to take the pump off the truck to do it, you just take the pump top off with the 4 alen keys
93 4X4 auto
cummins king
Postby gear jammer 91" » Wed Feb 20, 2008 6:21 pm
I never took the pump off the truck. I did have to loosen the mounting nuts cause I had the pump timed up against the head and I couldn't get to the idle screw. Once I moved it back away from the head it was pretty easy and only took a couple hours.
01 LB7
gear jammer 91"
