by CumminsPower59 » Sun Feb 16, 2014 6:33 pm
I've ran 18psi for a while, running 15-16 right now. I've ran 30psi on accident, and it held for 25 miles, 35 minutes of run time. You should be able to pull the pump, and use green LocTite to hold the seal, as it is a weeping type, gets down into the seal I guess. I think BC has used it before, if not, pull just the front seal and use red LocTite on a new seal. You should be fine running a LocTite'd front seal and 18psi.
