comotionman wrote:The stock ic put in 1stgens is better than nothing, but its undersized. The inlet/outlet tubes as well as the air horn are also undersized. Recognizing this, when I went to put an intercooler into my non ic 90 I didn't bother with the 1stgen stuff. I went with a psic, which is the abrev for powerstroke ic. Another and I feel better choice is the 2ndgen unit. You really can't go wrong with either. Along with 3" inlet/out charge tubes and an air horn with 3" inlet and you'll be set. I want to say around the 400hp level it becomes a real restriction but I am not sure, but the fact that the larger setup will provide cooler temps in all situations tells me the stock ic is an inferior setup.
blacksheep wrote:i will be putting a p-pumped 12v that should be 6-800 hp.
