Build plan?
Postby ryan10 » Mon Feb 11, 2008 1:24 pm
Ok, thanks. would this hx40 work?
http://cgi.ebay.com/ebaymotors/USED-403 ... enameZWDVW
Also, how about an H1E? i found one on ebay with no reserve. are they wastegated? is it a bolt on?
Will any hx40 bolt onto my truck? i have heard there are only certain ones that will bolt on.
thanks.
1993 w350 6" lift, 35" all terrains. fuel screw in as far as it will go, pump mods, bully dog injectors, bullydog fuel pin, 14cm wastegated housing, water/meth injection. Ground AFC foot, 3200 spring
soon to come: turbo upgrade.
ryan10
Postby ford69557ci » Mon Feb 11, 2008 1:56 pm
thats hx40 has the t-4 flange so it will not bolt up and usually the ones with the t4 had a large ex housing. the 16cm is the best one to find and will have a t-3 pattern that will bolt right to your manifold.
ford69557ci
Postby DTanklage » Mon Feb 11, 2008 3:40 pm
an h1c will work
depends on how you want it to work...
the s300 series turbos work really really good
DTanklage
Postby ford69557ci » Mon Feb 11, 2008 3:40 pm
yeah i would just save and get the s300 way better in the long run
ford69557ci
Postby cummins king » Mon Feb 11, 2008 5:58 pm
i got a good WH1C for sale, no play, with a 16cm housing, i looked for the s300 and man he only had one and he woulnt part with it, unless you buy the whole motor :lol:
93 4X4 auto
cummins king
Postby ryan10 » Mon Feb 11, 2008 7:10 pm
doesnt my truck already have an h1c? ive got a 14cm wastegated housing on it too
ryan10
Postby cummins king » Mon Feb 11, 2008 7:16 pm
sorry im going to have to check those numbers again, there not right
93 4X4 auto
cummins king
Postby ryan10 » Tue Feb 12, 2008 4:27 am
Ok, let me know what you have. could it be an H1E? either way, let me know what it is, because i am deffidently interested.
thanks.
ryan10
Postby ryan10 » Wed Feb 13, 2008 5:54 pm
Ok guys, with my mods and the ground AFC foot and 3200 spring, could i get away with a 60mm compressor wheel upgrade? im really looking to break into the 350/700 range. is this just too much to ask for this turbo? i really want to upgrade, just cant find anything in my price range.
any ideas?
ryan10
Postby cummins king » Wed Feb 13, 2008 7:20 pm
ya it was an h1c 16cm wastegated i thought it was an h1e but its not, why dont you get a s300 of hx40 and a 4inch exhaust and its done with, 350hp no problem, keep an eye on that bd fuel pin i sent mine back because it started to grove, they dont harden them enough
93 4X4 auto
cummins king
Postby DTanklage » Wed Feb 13, 2008 10:46 pm
ryan10 wrote:
....really want to upgrade, just cant find anything in my price range.
any ideas?
rob a bank?
DTanklage
Postby GO OVRIT » Thu Feb 14, 2008 4:15 am
There's mixed reviews on it, but the Master Power turbo from PDR is only $550 on sale.
GO OVRIT
Postby ford69557ci » Thu Feb 14, 2008 9:08 am
i have heard they like to break shafts worse than an hx 40
ford69557ci
Postby DTanklage » Thu Feb 14, 2008 10:48 am
if you "cant afford to upgrade" then just lower your goal to a more realistic number. one you can afford. geez. this aint rocket science. costs to go fast. if you dont have coin, your sthi aint gonna fly. period. instead of saying, "i am gonna do 350/750, and do it with what $$ i have...ask, "how much can i make with this much money"? i think you can use the stock turbo and get 325 or so, which is almost what you are trying to upgrade to
DTanklage
Postby burnt_servo » Thu Feb 14, 2008 10:57 am
DTanklage wrote:if you "cant afford to upgrade" then just lower your goal to a more realistic number. one you can afford. geez. this aint rocket science. costs to go fast. if you dont have coin, your sthi aint gonna fly. period. instead of saying, "i am gonna do 350/750, and do it with what $$ i have...ask, "how much can i make with this much money"? i think you can use the stock turbo and get 325 or so, which is almost what you are trying to upgrade to
i think you kind of answered a question that was rattling around in my head the last little while ;
at what horsepower level do things go from fairly inexpensive ( mostly modified stock parts , bhaf , big exhaust / exhaust housing ) to moderately expensive ( bigger injectors , bigger turbo , ic or bigger ic ect... ) ?
'93 w250 .... stock ...
burnt_servo
