Clutch cable?
Clutch cable?
Postby 92cummins89 » Wed May 14, 2014 4:01 pm
I'm guessing it's a cable but need to find an clutch cable or rod for my 92
I pushed the clutch in the other day and head a pop and end it or wat not dont think it's fixable
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Clutch cable?
Postby mknittle » Wed May 14, 2014 4:11 pm
Nope it is hydraulic. I am sure it is fixable.
mknittle
Re: Clutch cable?
Postby 92cummins89 » Wed May 14, 2014 4:14 pm
The rod for behind the peddle is bent
92cummins89
Re: Clutch cable?
Postby mknittle » Wed May 14, 2014 4:28 pm
In that case the master cylinder will likely need to be replaced.
mknittle
Re: Clutch cable?
Postby Tacoclaw » Wed May 14, 2014 5:29 pm
You can make a new, better rod if you feel like putting some work into it.
I'll sniff around and find the writeup on it.
Re: Clutch cable?
Postby 92cummins89 » Wed May 14, 2014 7:53 pm
Any help will b appreciated
92cummins89
Re: Clutch cable?
Postby Tacoclaw » Thu May 15, 2014 2:39 am
Tacoclaw wrote:(Obligatory "That's what she said" for all my rod references)
Did some clutch linkage work this evening, it helped but I think it's time for a fluid change in the ol' Getrag.
It's a little longer than the old rod, but my locknut is hella thick so I'll put one about 1/3 the thickness on there and it'll even things out. Right now I bottom out the master before the pedal hits the floor.
You can see where I cheated and "adjusted" the pedal with some cutting and welding when I first put it in. I also welded up and reground the pin in the pedal itself, but by some miracle the pot metal master rod ate through it already.
The user "Meiser" on here has a write up on how he fixed his the first time with epoxy and whatnot, but apparently it broke again and he documented his fix over on the Expedition Portal forum he seems to frequent the most. I'm gonna steal his other post about it and add it to the one here. With as much E-cred as possible. :)
Re: Clutch cable?
Postby Tacoclaw » Thu May 15, 2014 2:41 am
Re: Clutch cable?
Postby 92cummins89 » Fri May 16, 2014 7:44 pm
Where did u find the female rod in tho
Any store in particular ?
92cummins89
Re: Clutch cable?
Postby Tacoclaw » Fri May 16, 2014 7:58 pm
I found mine laying around at work, dunno where Metcalf found his.
You could get on Amazon and type in 3/8x3/8" rod end and probably get one in two days on Prime.
Re: Clutch cable?
Postby 92cummins89 » Fri May 16, 2014 8:15 pm
The actual plunger wat kinda rod is it ? Think tt said 3/8 or
92cummins89
Re: Clutch cable?
Postby 92cummins89 » Fri May 16, 2014 8:25 pm
Saw it said a bolt but I don't have access to a lathe wat else could I use ? Any ideas
92cummins89
Re: Clutch cable?
Postby 92cummins89 » Wed May 21, 2014 7:32 pm
Any idea where I can or does someone have the length of the rod at the other end of it
Like where it pushes on the piece connected to the throw out bearing
92cummins89
Re: Clutch cable?
Postby Tacoclaw » Wed May 21, 2014 7:41 pm
Honestly, you could take your old rod and a 3/8 bolt to anybody with a lathe and they could turn it out pretty much by eye. Even a machine shop wouldn't charge much for the job. Just make sure you give them a bolt that matches the thread in your rod end.
Re: Clutch cable?
Postby 92cummins89 » Fri May 23, 2014 7:11 pm
Any idea on the length an diameter of the rod connecting the cable to the throw out bearing and the boot tht goes around it
92cummins89
