Cummins/82 C10
Re: Cummins/82 C10
Postby ellis93 » Tue May 20, 2014 2:47 pm
IDK.....some looks good....some not so much. I just want something different,like the truck.
There are no pillar pods or Column mounted.....nothing really. This truck might be harder to find decent pods for than our dodges. Hell I made one work on the dash of my truck from a newer application,guess I could do it on this thing.
Re: Cummins/82 C10
Postby PToombs » Tue May 20, 2014 4:58 pm
You could use a bread pan like Bryan Moeller did. ;) How about a pillar pod for a 1st gen? Not close to fitting?
Re: Cummins/82 C10
Postby 1STGENFARMBOY » Wed May 21, 2014 9:38 pm
You could do like Richie O did, make your own and stretch it aaallllllllll the way across the dash.
the man never wanted for info on his engine after that......
Re: Cummins/82 C10
Postby DMan1198 » Thu May 22, 2014 8:40 am
I vote for the wood faced one you build. Match everything but the bezel of it to the dash color. I also vote for it to be mounted on the dash if that wasn't implied
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 8:03 am
I did some running around mobile this morning,hitting up the wreaking yards for pieces and parts. I pulled up to the last one and looked under the truck to find a huge puddle of oil,so I popped the hood
Mother freaker :mad:
I put "new" gaskets on this thing to keep schit like this from happening. Took two gallons of oil to get back to the shop,approximately 35miles. That's 30 bucks gone plus the aggravation of getting it fixed.....damn.
Re: Cummins/82 C10
Postby Tacoclaw » Thu Jun 26, 2014 8:41 am
What am I seeing, did I'd blow out of the bottom of the tappet cover?
Re: Cummins/82 C10
Postby dazedandconfused » Thu Jun 26, 2014 9:09 am
Tacoclaw wrote:What am I seeing, did I'd blow out of the bottom of the tappet cover?
Glad I'm not the only one missing something here
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 9:59 am
Red rubber gasket,protruding form the tappet cover. Look between the two fuel lines.
Re: Cummins/82 C10
Postby dazedandconfused » Thu Jun 26, 2014 10:13 am
I see it now.
Re: Cummins/82 C10
Postby DodgeFreak » Thu Jun 26, 2014 10:14 am
what is that thing for on the left side of the fuel pump?
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 10:26 am
Fuel heater/strainer.
Reckon why this happened anyhow. I did stab the throttle a couple of times,surly this thing ain't building that kind of crankcase pressure.
Re: Cummins/82 C10
Postby Tacoclaw » Thu Jun 26, 2014 12:28 pm
None of us could find it because your oil isn't pitch black like ours. :lol:
I'd try a little gasket-tack on it myself, I never put anything together without it anymore. I only use it on one side of the gasket, and that's whatever side comes off with a part so I can clean it off easily when I need to.
What's up with losing 2 gallons of oil through a non-pressurized gasket leak?
Re: Cummins/82 C10
Postby dazedandconfused » Thu Jun 26, 2014 12:31 pm
Are you sure your vent isn't clogged? I can't see why it would have done this myself other then crazy amounts of pressure buildup.
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 1:52 pm
Tacoclaw wrote:None of us could find it because your oil isn't pitch black like ours. :lol:
I used that 3m weather striping adhesive stuff last time,always do. That's why this is puzzling me.
Levi I reckon it's the 70lbs of oil pressure that motor produces,other than that idk.
Re: Cummins/82 C10
Postby ellis93 » Thu Jun 26, 2014 1:53 pm
dazedandconfused wrote:Are you sure your vent isn't clogged? I can't see why it would have done this myself other then crazy amounts of pressure buildup.
I'll be checking that just as soon as I unass this chair I'm in.
