S362 and 6x16s = 30psi ??
Re: S362 and 6x16s = 30psi ??
Postby cummins32 » Thu Jul 10, 2014 9:43 pm
It's got a .90 a/r exhaust housing.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Postby RCCUMMINS89 » Thu Jul 10, 2014 10:47 pm
That's a huge housing.... I would suggest going with a different exhaust housing.
Postby fatty » Thu Jul 10, 2014 11:08 pm
What size exhaust wheel? I don't think the turbo has anything to do with your max boost being so low. I make more than 30 with stock injectors and a 63/68/.88 T4 turbo, and when I was running some 7x12, it made 47 psi. Get the boost leak fixed and then get back to us.
Postby cummins32 » Sat Jul 12, 2014 12:35 am
What size housing should I go with ?
cummins32
Postby Tacoclaw » Sat Jul 12, 2014 3:57 am
Fix the boost leak before you spend $700 on an exhaust housing. Even some JB weld slapped over the hole for testing purposes would be better than spending that much without making sure everything is right first.
You oughta be able to make more than 30psi no matter how big your housing is.
Postby RCCUMMINS89 » Sat Jul 12, 2014 7:39 am
I would normally agree.... but with 6x16s, I see it being flooded out so hard down low that it never recovers. I've seen it a lot.
Either way, like mentioned... fix boost leaks first.
Postby cummins32 » Sat Jul 12, 2014 9:12 am
I'll fix the intercooler today and let you guys know, I'm pretty sure running more than 30 psi though, I had a hole in the hose going to my boost gauge, and thought I fixed it.
cummins32
Postby cummins32 » Sat Jul 12, 2014 9:19 am
Also I gotta Denny t stage 2 pin in it, think it's to steep of a ramp ? I've got the star wheel all the way up,
cummins32
Postby cummins32 » Sun Jul 13, 2014 9:23 pm
I'm getting 40 psi outta it, I still think something isn't right, I got a new hose for the boost gauge, I'm gonna buy a new intercooler, any ideas in where to get one ?
cummins32
Postby cummins32 » Sun Jul 13, 2014 9:36 pm
Also what about a .88a/r t4 exhaust housing ?
cummins32
Postby RCCUMMINS89 » Sun Jul 13, 2014 9:53 pm
.91 will spool faster than a .88 due to the .91 being divided. Is it the .91 or a .90?
What are your egts like now? You are going to have egt issues with a 62, pretty much regardless (with 6x16s). Do you know what turbine size it has yet?
Postby cummins32 » Mon Jul 14, 2014 7:21 pm
Not yet on the turbine size and Right now it's a non divided .90 housing, so you think I should get a divided t4 housing ?
cummins32
Postby cummins32 » Mon Jul 14, 2014 7:22 pm
Well my vss went out but in overdrive i could bury the gauge, but it's a glowshift and I could bury it before with 5x12s and an hx35
cummins32
Postby RCCUMMINS89 » Mon Jul 14, 2014 7:27 pm
If you're going to swing for a new housing.... go with a .80 T3 or a .83 T4.
Postby Tacoclaw » Mon Jul 14, 2014 7:28 pm
Just epoxy/JB weld that hole, dude. It makes literally no sense to spend that much money chasing something like that...
Once it's not leaking, check for more leaks, then see what you have going on.
