I have a 1989 Power Ram W100 with a 5.2L / 318c.i. V8 and auto trans......I believe a vacuum leak is my culprit....at startup, It will idle normally and then almost die down (repeating the sequence over and over)..I've checked the idle air control valve and it's OK.
Any suggestions / opinions on a different diagnosis??
What vacuum hoses should I check and how many are involved??
Thanks so much for all help possible!!
Mike
