fuel pressure
fuel pressure
Postby mitchk » Wed Jul 30, 2014 12:55 pm
I just noticed this today coming home from work. I didnt notice any change in the way the engine is running but the fuel pressure is just bouncing around. I checked all the lines and there doesnt seem to be any leaks anywhere. It almost seems like the rod from the lift pump is bouncing on its lobe. Has anyone ever had this happen. everything seems fine and the engine runs just as it has. i also just added 60# valve springs the other day but i doubt that should have anything to do with this.
Daily: 91 d350 727 gear vendors over drive, 3/8 feed line, THD lplp, maxed pump, Denny t 2, timing to head, #366 spring, 60# valve springs, arp studs, 60 horse injectors?(po), THD bahf, s362sxe
Project: 93 w250 5 speed, ground stock pin, #366 spring, 60# valve springs, THD lplp, intercooled compressor non intercooled turbine, diamond eye 4 inch, custom intake, south bend hd single
mitchk
Re: fuel pressure
Postby PToombs » Wed Jul 30, 2014 5:40 pm
Do you have a snubber or needle valve inline? I have a needle valve and I have to keep it almost closed or the gauge bounces so bad I can't read it.
Valve springs shouldn't make any difference.
Re: fuel pressure
Postby RCCUMMINS89 » Wed Jul 30, 2014 5:53 pm
ALL lift pumps bounce. Mechanical ones bounce like crazy... I would almost guarantee you had air in the lines that finally worked its way out.
I've messed with all of the aftermarket stuff to get rid of bouncing... the only way I've been able to do it... use about 5 feet of fuel line curled up under the dash, and leave air in the lines. It'll be dead accurate and won't bounce a lick.
