high idle sputter (video)
Postby Randy » Wed Sep 03, 2014 10:12 pm
hey what do you guys think the cause may be? only happens when i keep it high idle. fuel pump? fuel supply? timing? its a 92'
https://www.youtube.com/watch?v=yINKleIXDwg&list=UUTxAPHp56BjqOfCZi3c0wPQ
Randy
Re: high idle sputter (video)
Postby fatty » Wed Sep 03, 2014 10:27 pm
Why on earth would you ever have it revving like that in neutral?? If that's the only time it does it you should quit doing it.
Postby Randy » Wed Sep 03, 2014 10:45 pm
It happens while driving as well. Not only in neutral.
Randy
Postby Remps » Thu Sep 04, 2014 8:51 am
Does it do it with heavy throttle or just light throttle? If it only does it light throttle high rpm just don't drive it like that. My guess is a piece of your fuel shutoff in one of the delivery valves.
Postby fatty » Thu Sep 04, 2014 11:22 am
Try bumping the timing up an 1/8" or so.
Postby RCCUMMINS89 » Thu Sep 04, 2014 5:02 pm
Either timing, or the lift pump is sucking air at a certain point. I could see where the lift pump is too weak... the ip is over riding the lift pump at that high of a level and then sucking air, due to a vacuum through a bad lift pump.
Postby Randy » Thu Sep 04, 2014 5:26 pm
That's one of the possibilities I thought of. Upon further investigation - on the fuel tank is a rubber seal/grommet fits in between the plastic tank and the metal fill tube - that seal is broken, badly. I put one on order(5-7days out), however not sure if that is the cause/could be the cause.
I'm only going to be running it for teating/troubleshooting purposes as running a pump dry can cause internal failure.
Randy
Postby RCCUMMINS89 » Thu Sep 04, 2014 5:44 pm
Run a hose from a 5 gallon tank of diesel straight to the injection pump. Do the neutral thing and see if it goes away.
A VE CAN RUN WITH ZERO FUEL PRESSURE... AS IT HAS AN INTERNAL SUPPLY PUMP.
Postby Randy » Thu Sep 04, 2014 5:51 pm
Okay, I'll post results.
Randy
Postby AHineman » Fri Sep 05, 2014 6:42 pm
When's the last time you changed your fuel filter?
Postby Randy » Wed Sep 10, 2014 8:02 am
Clogged fuel filter. I purchased this truck around a month ago, previous owner claimed all filters had recently been changed (guess he doesn't know what recent means)
Replaced filter, but going to do an annual pmcs just to be safe.
Thanks for the posts everyone.
Randy
Postby Randy » Wed Sep 10, 2014 8:11 am
Also very possible that dust and dirt where able to come into the fuel tank through that broken seal, shortening the life of the filter drastically.
Randy
Postby DodgeFreak » Wed Sep 10, 2014 8:02 pm
fatty wrote:Why on earth would you ever have it revving like that in neutral?? If that's the only time it does it you should quit doing it.
I haven't watched the vid....but the way these engines are ...you can run them at wot against the gov with out problems for testing and what not....to check fuel pressure on Internationals we would do an idle fuel and a wot fuel test...
