Max hp from stock I/c injectors?
Postby Dan NJ » Sun Sep 07, 2014 9:12 am
So I used the search and turned up nothing, maybe I'm dumb and doing it wrong but I'm curious as to what is the max hp seen on stock injector? I'm kinda rolling the idea around of running a hx35 with gds 60mm wheel on my truck with stock injectors and turning the pump up. I'm really trying to gain hp without a ton of smoke.
Dan NJ
Re: Max hp from stock I/c injectors?
Postby oldestof11 » Sun Sep 07, 2014 4:29 pm
My rebuilt injectors put me at 15.5x at 84-85mph. At 6100 lbs, it's 250-260 at the rear wheels. I'm sure it'd be more if I had a real lift pump on it.
Postby CumminsPower59 » Sun Sep 07, 2014 10:50 pm
IIRC, RC made 414 on honed stock IC sticks ;)
Postby AHineman » Sun Sep 07, 2014 11:09 pm
Honed ≠ stock.
Postby oldestof11 » Mon Sep 08, 2014 4:37 am
But it shows the potential.
Postby fatty » Mon Sep 08, 2014 5:01 am
I made 283/512 a few years ago.
Postby AHineman » Mon Sep 08, 2014 5:29 am
Stock is stock. Modified is not stock.....
Edm, honing, whatever.
Postby Dan NJ » Mon Sep 08, 2014 9:50 am
Thanks guys, I'm not trying to get too crazy because when I did with my other cummins trucks it just got really expensive real fast
Dan NJ
Postby DMan1198 » Mon Sep 08, 2014 11:05 am
Iirc getting a set of nozzles extrude honed runs about $200. I haven't looked into stock replacement injector prices, but that'd be a pretty good budget friendly choice IMO
Postby RCCUMMINS89 » Tue Sep 09, 2014 10:21 pm
Stock will do about 300. And yes honing adds allot of power for cheap. We will hone them for 250
Postby Jonnylightening » Tue Oct 14, 2014 4:57 am
RCCUMMINS89 wrote:Stock will do about 300. And yes honing adds allot of power for cheap. We will hone them for 250
Soon as I get some cash flowin in im gunna see you bout a set of injectors
Jonnylightening
Return to Competition
