Larger pump drive gear ??
Postby cummins32 » Fri Sep 26, 2014 7:18 am
I was thinking, since a ve pump pushes more fuel at low rpms would a larger diameter gear reduce the pump rpms enough ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Larger pump drive gear ??
Postby PToombs » Fri Sep 26, 2014 5:43 pm
Won't work. You would have to fab a new gearcase to mount the pump farther from the cam, then it would screw up the fuel timing. The gear is sized to allow the pump to turn 1 revolution to the cranks 2 revs. Like a distributor, (which is actually is).
Postby cummins32 » Fri Sep 26, 2014 10:45 pm
Dang it, ok
cummins32
Postby BC847 » Sat Sep 27, 2014 11:38 am
Why would you want to lower the pump RPM?
