60# Valve Springs
60# Valve Springs
Postby dbshelton » Sat Sep 27, 2014 5:09 am
Are most all brands of 60# valve springs the same?
dbshelton
Re: 60# Valve Springs
Postby oldestof11 » Sat Sep 27, 2014 9:28 am
Some call it 90# but yes, pretty much.
Postby dbshelton » Sat Sep 27, 2014 3:23 pm
Thanks. I guess I will order a set from The Hungry Diesel.
dbshelton
Postby RCCUMMINS89 » Sun Sep 28, 2014 9:51 am
We have had excellent results with the Toxic Springs ($130).
Postby dbshelton » Mon Sep 29, 2014 7:36 pm
Thanks. I'll give them a shot. The main reason I need the springs is for when I install the HE351vgt turbo later on.
dbshelton
Postby RCCUMMINS89 » Mon Sep 29, 2014 9:48 pm
They'll be there on Thursday.
Postby dbshelton » Tue Sep 30, 2014 4:17 am
Thanks. Sounds like a Saturday project.
dbshelton
Postby 93flatbed » Tue Oct 07, 2014 7:57 pm
The 60# spring was a good choice until I started going past 55 psi. I had soot in my intake log after that.
BUT for what you are talking about doing it is a great spring. I was surprised on how it changed my idle sound.
93flatbed
Postby dbshelton » Wed Oct 08, 2014 7:14 pm
Changed out the valve springs, installed new valve stem seals, and adjusted the valves. Finished the Ford Bus exhaust manifold swap (Had to get the turbo reclocked by Turbo Power in Beaumont,TX since I couldn't budge it.) I can't put my finger on it, but the engine sounds different at idle. Sounds good to me. Maybe it's the thorough cleanup and fresh Cummins red paint job? Kinda purty now!!!!
dbshelton
Postby oldestof11 » Thu Oct 09, 2014 3:47 am
Is it a little more crisp sounding?
Postby charmander » Thu Oct 09, 2014 4:08 pm
Any reason for bigger valve springs other than rpm?
Boost?
90 W250, 35s, 727, hx35/40, coolertubz 3" crossover, pump turned up, 366 spring, denny t stg 2, timed to the head, raptor 150, arp studs
next up: intercooler
charmander
Postby oldestof11 » Thu Oct 09, 2014 4:23 pm
Boost and back pressure.
