fatty wrote:I have no advice to give, or other options for you.I hope you post lots of pictures though, everyone likes pictures!
Kroner wrote:I've got my friends driveline shop to help with correcting the angles. I've also looked into using a 1/2 ton lifted coil if I should need to
Kroner wrote:I shortened the frame 15" to make the wheelbase 116" overall. Was a lot easier than I thought it would be. The engine was moved 11" back. I thought I would have 1 1/2 cylinders under the dash but ended up with two. The exhaust housing is about 2" from the firewall so my hole will be larger than I thought. Track width turned out much better than I thought. Once I change it over to swr, 3rd gen rims shomakes olive the problem. Anyone have any suggestions on building a firewall?
