84 crew cab cummins conversion and suto to manual swap
Re: 84 crew cab cummins conversion and suto to manual swap
Postby KTA » Tue Oct 21, 2014 5:58 pm
Well I changed engine harness today to the 89 and my speedo now works and my wait to start isn't flashing anymore. I guess maybe the speedo signal runs through the grid heater module? I also got my radio in and working, now I am down to exhaust and my odometer doesn't work. I assume since I get a speedo reading the odo should be working too, but no doubt the gears are crapped out.
Postby KTA » Thu Oct 23, 2014 4:53 am
On the road again. http://youtu.be/_Z4MriDJyJw
Postby bgilbert » Thu Oct 23, 2014 3:02 pm
When will the 4x4 conversion begin? Will you be running CTD fender badges? Do you need them?
Bill Gilbert
Postby KTA » Thu Oct 23, 2014 3:58 pm
I am aiming for fuel economy and I won't ever be getting it out when there is salt on the roads so I haven't planned on a 4wd conversion. I will probably at some point swap at least the right side fender with the parts truck as the one on the crew has a cancer spot. I guess then it will get at least one badge. lol I would also like to swap the bedsides with the parts truck as it has excellent sides but the box is beat to sthi. My crew has a good box but the bedsides have cancer. If I win the lottery I will look into having a pro do that for me. I am not a body man. I loathe painting and sheet metal work.
Postby Loaded burrito » Tue Nov 18, 2014 6:00 pm
Looks great kta. Since when have you been back?
Loaded burrito
Postby dazedandconfused » Tue Nov 18, 2014 6:12 pm
Have you had any issues with it since you got it together?
Postby KTA » Thu Nov 20, 2014 3:05 pm
AFter getting the speedo fixed finally I only had a heater hose leaking where it goes to the core so I tightened the clamp, other than that it has been great and is getting a little better than 16mpg average with the 4.56's. I can't wait to put the 3.07's in and get 20mpg.....I hope.
