762frmafr wrote:My impression of these trucks was that being all mechanical, they would be "tougher" than this. I was figuring they would chew up and spit out a bit of old fuel. Is there any option in a lift pump I can install that will be more durable?
CumminsPower59 wrote:No base, its an inline strainer, very similar to an universal gasoline filter. Uses 3/8" inlet and outlet. Worked well for me since I upgraded the fuel supply and return lines to biodiesel compatible rubber line, an inexpensive upgrade in my opinion.
PToombs wrote:Too bad you didn't see my post above before you ordered them, I only get on once a day so I couldn't warn you sooner.
CumminsPower59 wrote:Apologies, I should have double checked before I posted...
RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
lz69 wrote:RCCUMMINS89 wrote:Will an i/c grill fit a non i/c core support?
From what I have read they have the headlight buckets in different locations. Remember seeing pictures where the owner cut up the core support and relocated them to match the different grill
Users browsing this forum: No registered users and 75 guests
