ellis93 wrote:O'Reilly's sells assortment packs that have what you need....inexpensive and in the help section/motor might
Also I've mashed several and used what I'm telling you to buy,absolutely no issues with them. I don't really think there is anything special about them or what cummins/Bosch installs.
Diesel wrote:You mean turn the engine to match the pump, tighten nut, then line up the timing line?
