'92 Cab Swap!
both inside and out
'92 Cab Swap!
Postby PToombs » Sat Feb 23, 2008 1:06 pm
Though I'd do a little show on my cab swap.
First, the outside garage,
Then the inside shop
Postby PToombs » Sat Feb 23, 2008 1:14 pm
Here's an inside look at the cab. Nice holes in the floor, huh?
Better shot of the drivers side floor. That is the ground! :shock:
More updates as I go! ;)
Postby PToombs » Sat Feb 23, 2008 1:16 pm
Heres some pics of the rear of the truck.
Donor frame,
Cab shot,
Rear with the stacks, working on the aux tank,
Postby PToombs » Sat Feb 23, 2008 1:17 pm
Here is the cab, minus floor.
Here is the hump, ready for paint.
These are the cab, ready to paint. I put rust killer stuff on the floor.
Postby PToombs » Sat Feb 23, 2008 1:18 pm
In the last pic, don't mind that little spot at the lower right of the hole. Somebody wasn't paying attention and cut on the wrong line! :oops: It took me close to an hour to weld that back up and grind it sorta smooth. I'm sure the undercoating didn't help. 110 MIGs are crappy! ;-)
Postby oldcool90 » Sat Feb 23, 2008 4:21 pm
I thought you was putting on the new cab to get away from the holes. ;) Look's good pete,that job takes up some time!!!! Weld you a flange on your tunnel and put some of them fastenrs that the drag racers use on it,that would make easy acess to the ole 5sp.
oldcool90
Postby burnt_servo » Sat Feb 23, 2008 6:49 pm
oldcool90 wrote:I thought you was putting on the new cab to get away from the holes. ;) Look's good pete,that job takes up some time!!!! Weld you a flange on your tunnel and put some of them fastenrs that the drag racers use on it,that would make easy acess to the ole 5sp.
my 77 powerwagon and my 54 m37 both have that , a bolt in transmission tunnel .....
kind of surprised that dodge did away with it in the later models .
'93 w250 .... stock ...
burnt_servo
Postby oldestof11 » Sat Feb 23, 2008 6:57 pm
Looks good Pete!
That rust area on the floor of the first cab, that was how big the hole was in my floor :shock: The rubber mats kept me from going under.
Postby PToombs » Sun Feb 24, 2008 2:46 pm
The donor floor, is an 86. It had the pressed marks where the floor would be cut out for a standard. I followed those, for the most part.
Matt, dzus fittings? Ever price those? :shock: I know you wouldn't buy 'em! :money:
Simple tech screws will work just fine! ;)
Postby Philip » Sun Feb 24, 2008 3:09 pm
You can tell in the last pic it is a Dodge cab real easy. Its well oiled. :lol:
Postby CAJUN 93 » Mon Feb 25, 2008 9:45 am
man, you weren't lying when you told me thats a big undertaking. i dont know if i'de get myself into that big of a deal
daryl
CAJUN 93
Postby PToombs » Mon Feb 25, 2008 4:53 pm
Thanks Daryl, You're about the 3rd person to boost my confidence way up! :grrr:
Actually, I don't think it's that bad. The floor I was dreading, but that took about 4 hours, total time. Swapping stuff is easy, I just wish I had more room to work. Everything inside 1 room would be the bomb! :bom:
Postby TWorline » Mon Feb 25, 2008 5:53 pm
If you could just figure out how to get some of the oil the tranny was collecting over on the other side of the frame rail.... :grin: I finaly figured out where the water was coming in at that used to drip on my left knee and also on my turn signal lever, the caulk in the driprail was cracked. I smoothed some gray silicone RTV in there and no more leaks. :D
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Tue Feb 26, 2008 4:54 pm
Tim, I tried that with mine, it was the window leaking. I'm sure that's what did the floor in. :cry:
Postby dpuckett » Wed Apr 02, 2008 6:20 pm
TWorline wrote:....I finaly figured out where the water was coming in at that used to drip on my left knee and also on my turn signal lever, the caulk in the driprail was cracked....
My girlfriend and I were looking at one of our 1stGens the other day, and thought it looked like plain RTV silicone caulk under the flaking paint, but thought "nah, cant be." Is it really siliconed, then painted? If so, I'm bringing about 4 tubes home from work this weekend and having fun with some Scotchbrite and rattle cans. I have two, maybe three trucks that need attention. Be nice to get the floors dry and keep them that way. Especially if we keep getting 8-12" of rain per week.
DP
Return to Body
