PToombs wrote:Tom, Can I pull the valve body from a 47RE and install a gasser 47RH valve body with the diesel springs and have a 47RH? Or are there other differences?
DMan1198 wrote:http://www.cumminsforum.com/forum/4th-gen-performance-parts-discussion/1448738-turbo-setups-tow-rigs-video-2.html#post16696026
It'll be in the last couple pages. Having 40 posts per page has its perks. Letting others see what part of a thread I'm talking about is not one of them
cmann250 wrote:I'm not Tom, but in order for an RH to shift on its own you need a governor in the tail housing.
txs wrote:Pete, you'd have to change out the overdrive housing and works also, that's where the governor is, all of them I've ever seen, the units with the gov in them are a good bit longer, maybe six inches or so.
DMan1198 wrote:I stumbled onto it on cumminsforum, and can't remember how to find it for the other forums
