RCCUMMINS89 wrote:Measure the diameter of the tip stock are 9mm
i guess an upgraded would be a 7mm duh sorry for the dumb question theyre definately stock then i measured 9mmRCCUMMINS89 wrote:Measure the diameter of the tip stock are 9mm
RCCUMMINS89 wrote:There are a 5 hole (not stock) available for them.... but highly unlikely. If they are 9 and have 4 holes.... they are stock.
manostihl wrote:RCCUMMINS89 wrote:There are a 5 hole (not stock) available for them.... but highly unlikely. If they are 9 and have 4 holes.... they are stock.
theyre stock. why wouldnt the 5 hole be likely. how do you guys do a compression test on these motors?
AHineman wrote:manostihl wrote:RCCUMMINS89 wrote:There are a 5 hole (not stock) available for them.... but highly unlikely. If they are 9 and have 4 holes.... they are stock.
I've got a snap-on compression tester with the adapter for the 12v cummins. I bought (ordered and returned) and or borrowed a couple of cheaper sets that were supposed to have the right adapter, but none had the correct pieces.
RCCUMMINS89 wrote:You'll always get some fuel. If you didn't you could fry the h/r assembly with an fss failure.
