AHineman wrote:I said this in your other thread, but I ordered one from Napa and the threads were wrong on the piece that goes in the injector hole....I borrowed one that came from harbor freight and it wasn't right either.
PToombs wrote:I'd say no, it doesn't list an adapter for a Cummins. The other thing is if you use a generic adapter like that black one, it's too short. When you test it you may get 250psi and you will think you have low compression, when the adapter is actually too small and you can't build up the compression enough because it doesn't fill the injector hole. We made some at work, and if they aren't right they aren't accurate. You can compare between cylinders to see if 1 is lower than the others, but the reading is low across the board.
manostihl wrote:AHineman wrote:I said this in your other thread, but I ordered one from Napa and the threads were wrong on the piece that goes in the injector hole....I borrowed one that came from harbor freight and it wasn't right either.
O i forgot sorry
AHineman wrote:manostihl wrote:AHineman wrote:I said this in your other thread, but I ordered one from Napa and the threads were wrong on the piece that goes in the injector hole....I borrowed one that came from harbor freight and it wasn't right either.
O i forgot sorry
No biggie.![]()
Why do you need one, as in do you want to check it because of the miss you were talking about?
