Odd....don't remember having to brake to have the windows...
Postby eyoung429 » Mon Feb 25, 2008 1:23 pm
Work?? I just got a call from my son who has been using my '91 to go to work in....been laid up for a bit due to camry that didn't like me.
Thing is, he has all lights,signals, door locks work, wipers and pump. But when he needs to open or close the windows, he stated that he has to have his foot on the brake.......
any ideas??? I can't look at the truck till at least friday when I get released from the hospital...
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby burnt_servo » Mon Feb 25, 2008 2:08 pm
i'm really hoping he has power windows :D
has he checked the ground wires off of the battery that ground onto the rad support ? ..... and even if it looks good , add a second one that grounds onto the body and engine and negitive battery terminal .
then from there check out how the window motors are grounding , even running a temp ground wire directly to the batery to trouble shoot .
'93 w250 .... stock ...
burnt_servo
Return to Electrical
