2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby matthewh » Thu Mar 12, 2015 6:43 pm
I just happened across it while surfing local Craigslist.
After doing some research, looks pretty easy to swap over, other than deciding whether to use the wastegate, and having some goofy intercooler piping, or tack welding it shut and clocking it to use the stock setup
matthewh
Postby CumminsPower59 » Thu Mar 12, 2015 10:10 pm
I thought I had a decent one, paid $315 for it. Got it and the compressor wheel was chewed up and the wastegate opening was slightly larger than the disk that seals it. Guy was cool about it and I got my money back. Started looking at ones again, found one for $220...and not modified at all, stock take off. Good enough.
Postby oldestof11 » Fri Mar 13, 2015 3:29 am
matthewh wrote:I just happened across it while surfing local Craigslist.
I tried clocking it 6 ways to Sunday. Ended up having a buddy weld a pipe to fit.
Postby matthewh » Fri Mar 13, 2015 9:22 am
You have any pictures? I've been researching more, watched couple YouTube videos, etc.
If I get one, ill probably just weld the wastegate closed, since I'm not push alot of fuel
matthewh
Postby oldestof11 » Fri Mar 13, 2015 6:20 pm
I'm going to try uploading some tomorrow.
I'm keeping the wastegate and solenoid. Thinking of getting a Raspberry Pi or Audrino mini computer. Use it to have 3 adjustable setting. I'll need 2 outputs and 6 inputs. 3 setting would be Econ, Tow, and Race. All 3 would use TPS, MAP, and speed. For Econ, it would keep a valet closed and possibly using a solenoid to open the waste gate some. Less back pressure, more efficiency off boost.
Tow would use an additional sensor, EGT. Using a variable solenoid, it would limit boost to the AFC depending on EGTs and the other sensors.
Race would be an anti slip, full power setup. Using a setup similar to aftermarket cruise, a front wheel with a magnet would read actual speed while the computer compares it to the speedometer reference. This will have a determined amount of percentage slip. If it goes beyond a certain percentage, it will slowly close the AFC off until traction is gained again. Then it'll ramp the AFC back up.
Postby cmann250 » Fri Mar 13, 2015 6:54 pm
Do not EVER get rid of a FSM! :mad:
Any one have tips on cam removal and installation? I'm helping my buddy with a cracked gear case tomorrow.
Postby fatty » Fri Mar 13, 2015 7:41 pm
Its much easier with the engine on a stand. Flip upside down so the tappets don't fall out then simply pull the cam out. It's easier if the oil pan is off so someone can hold it up to clear the lobes. :D
BC did a good writeup on DTR. It's in the sticky.
Postby Tacoclaw » Sat Mar 14, 2015 3:58 am
Yup, BC's thread is the shiznit, it's what I used to change mine. It's a simple job as long as you're just pulling the cam and stabbing it back in, changing the lifters is where the real pain begins.
Postby cmann250 » Sat Mar 14, 2015 4:04 am
I'll have to read the sticky. Thanks guys.
This one is on a stand so it should be easy.
Levi! Glad to see you back. :lol:
Postby matthewh » Sat Mar 14, 2015 5:11 am
oldestof11 wrote:I'm going to try uploading some tomorrow.
:shock: That's an ambitious project, sounds pretty awesome if you can get it to work
matthewh
Postby oldestof11 » Sat Mar 14, 2015 5:53 am
One thing I hate about racing 2wd is the lack of good boosted launches. I can do 5psi on stock tires but anymore and it boils them.
Postby Tacoclaw » Sat Mar 14, 2015 7:02 am
You could buy a new set of slicks, a jack, and an electric impact for the price of all that turbo stuff. :P
Postby fatty » Sat Mar 14, 2015 8:08 am
cmann250 wrote:I'll have to read the sticky. Thanks guys.
I was joking about the stand since I figured you were working in frame. I actually just pulled my cam with the engine upside down on a stand. I had my brother supporting the far end of the cam while I pulled the gear end out.
Be sure you check the tappets for wear and replace if necessary. About half of mine were pock marked.
Postby oldestof11 » Sat Mar 14, 2015 9:01 am
Tacoclaw wrote:You could buy a new set of slicks, a jack, and an electric impact for the price of all that turbo stuff. :P
$30 for computer
I have wiring
I have a solenoid
Just need a pressure switch and time.
Postby oldestof11 » Sat Mar 14, 2015 9:09 am
I also have slicks but need $300 in wheels. Its all money.
