Cummins/82 C10
Re: Cummins/82 C10
Postby ellis93 » Tue Apr 14, 2015 3:09 pm
Pulling it down. Used the last 1 1/2hrs at the shop today to pull the tins.
~original
Re: Cummins/82 C10
Postby ellis93 » Wed Apr 15, 2015 6:47 pm
And....its out
Get outa here dang you :lol:
Now for this junk
And it just fell out.....after I jacked up the dang cab
It's one greasy pos too. I think it's going back in Orange like the other engine as well.
Re: Cummins/82 C10
Postby cmann250 » Thu Apr 16, 2015 3:24 am
Paints engine Chevy orange => engine does not run well
Coincidence? I think not :lol: Why would you do that to another engine?
Re: Cummins/82 C10
Postby ellis93 » Thu Apr 16, 2015 3:26 am
:o RICHARD!
:lol: you might be on to something.
Re: Cummins/82 C10
Postby PToombs » Thu Apr 16, 2015 5:12 pm
Out with the bad, in with the worse! I agree with Caleb, if it was spoda be orange it would have come that color. ;)
Re: Cummins/82 C10
Postby ellis93 » Thu Apr 16, 2015 7:16 pm
And now there's two Richards :lol:
Yeah I'm thinking on keeping it black solely becuase of time. I have little interest in playing with it. I just want it to run.
I am grinding off that dodge stuff tho :lol:
Re: Cummins/82 C10
Postby DMan1198 » Fri Apr 17, 2015 1:37 pm
I was worried about the dodge bit being embossed like the 1st, and 2nd gen covers, so I checked my 24v cover, and the letters can be ground off.
Re: Cummins/82 C10
Postby dazedandconfused » Fri Apr 17, 2015 2:00 pm
How many miles are on that 24V?
Re: Cummins/82 C10
Postby RumbleFish » Fri Apr 17, 2015 2:27 pm
Oh....THAT orange. I wrongly assumed it was the correct orange. As in the Hemi variety. Corporation blue is also acceptable.
x3 on running poorly. That motor aint happy dressed up like that.
Re: Cummins/82 C10
Postby fatty » Fri Apr 17, 2015 4:05 pm
I'd complain too if I was forced to wear homo clothes. Poor thing.
Re: Cummins/82 C10
Postby ellis93 » Fri Apr 17, 2015 4:07 pm
dazedandconfused wrote:How many miles are on that 24V?
250k. Better than the last. I tore into it today....pulled the pan,side cover,valve cover,timing cover/case. It is mint inside and a bunch of cross hatch left in the cylinders. I'm very happy with its condition.
Jeff that's what I'm doing.....I bought a can of black for touch up.
Dman yeah I seen that today.....its coming off.
Well today,as mention above I tore the vp parts off and got the ve case swapped over. Also started fitting the pump to the enigne,grinding down the head to allow the pump to rotate to at least the factory ve timing marks. I had to do that just to have the throttle arm rotate without hitting. It will probably never get that far but if I have to i can,once the pumps in place the gear will be advanced one tooth so the pump position will likely be inbetween the mark and fully retarded.
Tomorrow will be a toss up....if it rains here I'll be working on the truck,if not then I'll be mowing grass.
Re: Cummins/82 C10
Postby ellis93 » Fri Apr 17, 2015 4:08 pm
fatty wrote:I'd complain too if I was forced to wear homo clothes. Poor thing.
You don't look in the mirror often do you? :lol:
Re: Cummins/82 C10
Postby PToombs » Fri Apr 17, 2015 5:10 pm
This is starting to get like Levis thread. He'll be getting all butthurt, or jealous, it's hard to tell which! :lol:
Re: Cummins/82 C10
Postby ellis93 » Fri Apr 17, 2015 5:51 pm
It's all in good fun....he knows that :lol: I think ;)
Re: Cummins/82 C10
Postby oldestof11 » Fri Apr 17, 2015 6:47 pm
If it is going like Levi's thread, butthurt. Not because of internet bullying either. :lol:
