Something cool I found at a local offroad expo
Postby dvst8r » Fri Feb 29, 2008 9:27 pm
It is on a 3rd gen, but it is still really cool.
Another view
On the truck
In Cermichrome
The inside transitions
What I found it on
No I do not make these, I just came across them at an off road expo and thought it was really cool. :grin:
dvst8r
Postby Begle1 » Fri Feb 29, 2008 9:31 pm
No external wastegate provisions?
What a piece of crap. :lol:
Postby dvst8r » Fri Feb 29, 2008 9:33 pm
Begle1 wrote:No external wastegate provisions?
Funny, I thought well where do I put the Primary now?
dvst8r
Postby nooblet » Fri Feb 29, 2008 10:53 pm
There was some build where a guy put a p-pumped Cummins in a suburban around a while back. He made a custom header for it and it looked a lot like that. His build was on one of the Cummins-conversion sites. He showed how he built the header, it was sick!
Chris
nooblet
Postby MikeThomas » Fri Feb 29, 2008 11:52 pm
Looks like a great way to take up space and build heat in the engine compartment! :roll:
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby rbrettctd » Sat Mar 01, 2008 6:51 am
The polished one looks a lot more organized. Other than that, they look crappy! There is a company making them that look straight and nice, but go for about $1k
Randy
rbrettctd
Postby PToombs » Sat Mar 01, 2008 7:07 pm
There was a big thread on TDR about those. Guy was looking for interest in building them. He did a lotta testing. Nobody had much faith in how long they would work before they broke. :shock:
Postby TWorline » Sat Mar 01, 2008 9:48 pm
Someone finally labled the "passenger" side of the truck, that ought to clear up alot of confusion! ;-)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby ford69557ci » Sat Mar 01, 2008 11:37 pm
yeah i was really confused at what side the ex manifold mounted on but that solves my mystery :rock:
ford69557ci
Postby greasemonkey » Sun Mar 02, 2008 1:44 am
PToombs wrote:Nobody had much faith in how long they would work before they broke. :shock:
it ain't going to last very long at all! with the volume of heat energy and the 600-1200+ degree fairly rapid heat cycles the tubing just can't hold up. tubing barely holds up on small block twin turbos before they crack out. and like Mike mentioned, you get to use heat energy to melt plastic stuff instead of drive the turbine! awesome!
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby PToombs » Sun Mar 02, 2008 7:40 am
I'd love to have one just for the :2cool: factor. Open the hood, everybody goes :hs: I just don't like the idea of spending $1k and being in the middle of Indiana in 3-4 years and have the manifold break off! :shock: :pottytrain:
Postby dvst8r » Sun Mar 02, 2008 10:43 am
From what I understood from the guys that I talked to those manifolds were designed for the Kore race team to run the BAJA 1000. If they last 1000 miles like that, I think they would last a life time on any of our trucks. Passenger is the name of the company that designed / manufactured them. Iirc the full name was Passenger Thermodynamic Engineering.
dvst8r
Postby dvst8r » Sun Mar 02, 2008 10:45 am
I dunno if they would crack that quick, I picked the black one up at the show (didn't want to get fingerprints on there nice shinny one) and it must have been fairly thick wall tubing as it must have weighed 50lbs+
dvst8r
Postby GO OVRIT » Sun Mar 02, 2008 11:27 am
The KORE trucks don't heat and cool all that many times. They get hot and stay pretty hot until they're done. It does look pretty trick though.
GO OVRIT
Postby TWorline » Sun Mar 02, 2008 1:41 pm
Pete:
The whole thing would not break off :roll: probably just the turbo so it would take you 18 hrs. to get home! ;-)
Tim Worline
TWorline
