ellis93 wrote:265/75's will rubb if not aired to 70 or 80psi on a dually...loaded. 245/75 are short but will fit well....better than a 235/75 will
ellis93 wrote:1" spacer between the wheels will make the 265's clear nice. A 265/75/16 is the same height as a 235/85 so you'll stay the same on the final drive ratio.
