full power screw/ 3200 spring
Postby bigtrev » Wed Aug 19, 2015 7:56 pm
Ok so I've installed the 3200 spring love it great product my only problem is I seem to have less top end a loss of 4 pounds of boost and what seems to be less smoke I have a read a million different forums but nothing has satisfied my question I have the full power screw completely bottomed out as I did before the 3200 I am wondering if maybe the 3200 spring is altering the full fuel setting to be less I tried indexing the throttle and turning down the idle with no success it reved High so I indexed back to stock don't know if I need to index then turn down the fuel screw to lower revs will this give me more fuel I am lost at this point maybe some one can shed some light
bigtrev
Re: fuel pin 3200 spring
Postby bigtrev » Wed Aug 19, 2015 8:13 pm
Also wanted to add that I was dead set to weld some extra length on my fuel pin until I read about indexing past stock I just want to know if my theory is correct that the 3200 spring does alter full power settings and will be less after 3200 spring thus needing to increase fuel settings to have the same power.i had before but through out the whole band also racking my brain that I have a factory lift pump (brand new) and maybe I have less power due to it fueling so much more down low so it's hitting 0 psi before I can get to max boost creating a lean mixture limiting boost
bigtrev
Postby bigtrev » Fri Aug 21, 2015 8:12 pm
Oh every ones input has been so very helpful :) off to weld pin I would post results but I don't think any ones listening hahahahahhahah
bigtrev
Postby AHineman » Sat Aug 22, 2015 6:29 am
You're killing me with the no punctuation. ;)
Fuel pin or fuel screw?
Postby bigtrev » Sat Aug 22, 2015 7:28 am
Yea this whole post is about full power screw I added 3/8 to my fuel screw turned out awsome gained what I was looking for now hitting 34 psi with no trailer stock turbo with 16 cm housing and as for punctuation ..........................,,,,,,,,,,,,,,,,,,,,,,,,,,.....,,,,
That should be enough to cover what I missed lmao I never use on forums seems like a waste of time but I guess
bigtrev
Postby Douglas » Thu Aug 27, 2015 5:13 am
bigtrev wrote:Yea this whole post is about full power screw I added 3/8 to my fuel screw turned out awsome gained what I was looking for now hitting 34 psi with no trailer stock turbo with 16 cm housing and as for punctuation ..........................,,,,,,,,,,,,,,,,,,,,,,,,,,.....,,,,
Proper writing is *NEVER* a waste of time, especially under these circumstances when you are trying to thoroughly describe an isue you need guidance on.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: full power screw/ 3200 spring
Postby cmauz61 » Thu Aug 27, 2015 9:59 pm
did you re index your throttle after installing the new spring? i know when i put the 4200 spring on i had to re index my throttle. or check that your fuel pin is getting full travel..
34 pounds of boost sounds right with stock everything. i make the same boost maxed out
1992 dodge w250 12v
4" turbo back exhaust, denny t fuel pin, 12mm pump cranked, 4,200 rpm spring, afe intake/filter, egt gauge, boost gauge.
cmauz61
